REST API reference
Delete a privilege tuple from the role
Removes a specified privilege tuple from a role, which affects the role's access to certain REST URIs. Use this when you need to modify role permissions by deleting access to specific resource endpoints.
HTTP method and endpoint
DELETE /security/roles/{owner.uuid}/{name}/privileges/{path}
Introduced in
ONTAP 9.6
Usage notes
Deletes a privilege tuple (of REST URI and its access level) from the role. The REST URI can be a resource-qualified endpoint. Currently, the only supported resource-qualified endpoints are /api/storage/volumes/{volume.uuid}/snapshots and /api/storage/volumes//snapshots. "" is a wildcard character denoting "all" volumes.
Required parameters
  • owner.uuid - UUID of the SVM which houses this role.
  • name - Name of the role to be updated.
  • path - Constituent REST API path to be deleted from this role. Can be a resource-qualified endpoint (example: /api/storage/volumes/43256a71-be02-474d-a2a9-9642e12a6a2c/snapshots). Currently, resource-qualified endpoints are limited to the "snapshots" endpoint: /api/storage/volumes/{volume.uuid}/snapshots and /api/storage/volumes//snapshots. "" is a wildcard character denoting "all" volumes.
  • security login rest-role delete
owner.uuid
string
path
True
Role owner UUID
name
string
path
True
Role name
path
string
path
True
REST API path
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
5636169
Specified URI path is invalid or not supported. Resource-qualified endpoints are not supported.
5636170
URI does not exist.
5636172
User accounts detected with this role assigned. Update or delete those accounts before deleting this role.
5636173
This feature requires an effective cluster version of 9.6 or later.
5636184
Expanded REST roles for granular resource control feature is currently disabled.
5636185
The specified UUID was not found.
5636186
Expanded REST roles for granular resource control requires an effective cluster version of 9.10.1 or later.
13434890
Vserver-ID failed for Vserver roles.
13434893
The SVM does not exist.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
