Delete a privilege tuple from the role
Deletes a privilege tuple from a role, which removes the specified access permissions related to REST URI or command paths. Use this operation when you need to update or refine the access control for existing roles.
HTTP method and endpoint
DELETE /security/roles/{owner.uuid}/{name}/privileges/{path}
Introduced in
ONTAP 9.6
Usage notes
Deletes a privilege tuple (of REST URI or command/command directory path, its access level and an optional query) from the role. The REST URI can be a resource-qualified endpoint. Currently, the only supported resource-qualified endpoints are the following:
Snapshots APIs
– /api/storage/volumes/{volume.uuid}/snapshots
File System Analytics APIs
– /api/storage/volumes/{volume.uuid}/files
– /api/storage/volumes/{volume.uuid}/top-metrics/clients
– /api/storage/volumes/{volume.uuid}/top-metrics/directories
– /api/storage/volumes/{volume.uuid}/top-metrics/files
– /api/storage/volumes/{volume.uuid}/top-metrics/users
– /api/svm/svms/{svm.uuid}/top-metrics/clients
– /api/svm/svms/{svm.uuid}/top-metrics/directories
– /api/svm/svms/{svm.uuid}/top-metrics/files
– /api/svm/svms/{svm.uuid}/top-metrics/users
In the above APIs, wildcard character * could be used in place of {volume.uuid} or {svm.uuid} to denote all volumes or all SVMs, depending upon whether the REST endpoint references volumes or SVMs.
Required parameters
owner.uuid- UUID of the SVM which houses this role. -
name- Name of the role to be updated. -
path- Constituent REST API path or command/command directory path to be deleted from this role. Can be a resource-qualified endpoint (example: /api/svm/svms/43256a71-be02-474d-a2a9-9642e12a6a2c/top-metrics/users). Currently, resource-qualified endpoints are limited to the Snapshots and File System Analytics endpoints listed above in the description.
Related ONTAP commands
security login rest-role delete -
security login role delete
owner.uuid |
string |
path |
True |
Role owner UUID |
name |
string |
path |
True |
Role name |
path |
string |
path |
True |
REST API path or command/command directory path |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1263347 |
Cannot modify pre-defined roles. |
5636169 |
Specified URI path is invalid or not supported. Resource-qualified endpoints are not supported. |
5636170 |
URI does not exist. |
5636172 |
User accounts detected with this role assigned. Update or delete those accounts before deleting this role. |
5636173 |
This feature requires an effective cluster version of 9.6 or later. |
5636184 |
Expanded REST roles for granular resource control feature is currently disabled. |
5636185 |
The specified UUID was not found. |
5636186 |
Expanded REST roles for granular resource control requires an effective cluster version of 9.10.1 or later. |
13434890 |
Vserver-ID failed for Vserver roles. |
13434893 |
The SVM does not exist. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
