REST API reference
Delete a privilege tuple from the role
Removes a privilege tuple from a role, which includes the REST URI or command path along with its access level and any optional queries. This action is useful when you need to update or refine role permissions by eliminating specific access points.
HTTP method and endpoint
DELETE /security/roles/{owner.uuid}/{name}/privileges/{path}
Introduced in
ONTAP 9.6
Usage notes
Deletes a privilege tuple (of REST URI or command/command directory path, its access level and an optional query) from the role. The REST URI can be a resource-qualified endpoint. Currently, the only supported resource-qualified endpoints are the following:
Snapshots APIs
– /api/storage/volumes/{volume.uuid}/snapshots
File System Analytics APIs
– /api/storage/volumes/{volume.uuid}/files
– /api/storage/volumes/{volume.uuid}/top-metrics/clients
– /api/storage/volumes/{volume.uuid}/top-metrics/directories
– /api/storage/volumes/{volume.uuid}/top-metrics/files
– /api/storage/volumes/{volume.uuid}/top-metrics/users
– /api/svm/svms/{svm.uuid}/top-metrics/clients
– /api/svm/svms/{svm.uuid}/top-metrics/directories
– /api/svm/svms/{svm.uuid}/top-metrics/files
– /api/svm/svms/{svm.uuid}/top-metrics/users
ONTAP S3 APIs
– /api/protocols/s3/services/{svm.uuid}/users
Artificial Intelligence Data Engine (AIDE) APIs
Data Compute Node (DCN) APIs
– /api/dcn/cluster/nodes/{node.uuid}/metrics
– /api/dcn/network/ports/{port.uuid}/metrics
Data-Engine APIs
– /api/data-engine/policies/{policy.uuid}/versions
– /api/data-engine/workspaces/{workspace.uuid}/acls
– /api/data-engine/workspaces/{workspace.uuid}/data-collections
– /api/data-engine/workspaces/{workspace.uuid}/data-collections/{datacollection.uuid}/acls
– /api/data-engine/workspaces/{workspace.uuid}/data-collections/{entity.uuid}/entities
– /api/data-engine/workspaces/{workspace.uuid}/data-collections/{datacollection.uuid}/search
– /api/data-engine/workspaces/{workspace.uuid}/data-collections/{datacollection.uuid}/versions
– /api/data-engine/workspaces/{workspace.uuid}/data-collections/{datacollection.uuid}/versions/{version.uuid}/diffs
– /api/data-engine/workspaces/{workspace.uuid}/data-sources
– /api/data-engine/workspaces/{workspace.uuid}/entities
– /api/data-engine/workspaces/{workspace.uuid}/entities/{entity.uuid}/custom-attributes
– /api/data-engine/workspaces/{workspace.uuid}/queries
– /api/data-engine/workspaces/{workspace.uuid}/queries/{query.uuid}/entities
– /api/data-engine/workspaces/{workspace.uuid}/versions
– /api/data-engine/workspaces/{workspace.uuid}/versions/{version.uuid}/diffs
When used in the context of data collection APIs, {version.uuid} refers to a data collection version. In the context of workspace APIs, it refers to a workspace version.
In the APIs above, and in the context of REST roles, the wildcard character * can be used in place of {volume.uuid} or {svm.uuid} to represent all volumes or all SVMs, depending on whether the REST endpoint references volumes or SVMs. The {volume.uuid} corresponds to the -instance-uuid field in the output of the "volume show" command at the diagnostic privilege level. It can also be retrieved through the REST endpoint /api/storage/volumes.
In the AIDE APIs described above, and in the context of REST roles, the wildcard character * can be used in place of variable components in the Uniform Resource Identifier (URI) path, such as {node.uuid}, {port.uuid}, {policy.uuid}, {workspace.uuid}, {datacollection.uuid}, {entity.uuid}, {version.uuid}, or {query.uuid}. The specific variable to be replaced depends on whether the REST endpoint references nodes, ports, policies, workspaces, data collections, entities, versions, or queries.
However, when using the wildcard character * in place of a variable component in a URI path, it must replace
all variable components in that path. Mixing wildcards and specific values for different variable components within the same URI path is not supported in REST roles. For example, a URI path such as /api/data-engine/workspaces/c6e1b325-4125-11f0-abb5-bc2411f6fd43/data-collections/*/search is not supported.
In summary, only the following two types of resource-qualified endpoints are supported in a REST role:
  • All variable components in the URI path are specific values. Example: /api/data-engine/workspaces/c6e1b325-4125-11f0-abb5-bc2411f6fd43/data-collections/b09b6d25-4126-11f0-abb5-bc2411f6fd43/search
  • All variable components in the URI path are wildcards. Example: /api/data-engine/workspaces//data-collections//search
AIDE APIs are supported only in cluster-scoped REST roles, not in SVM-scoped REST roles.
Required parameters
  • owner.uuid - UUID of the SVM which houses this role.
  • name - Name of the role to be updated.
  • path - Constituent REST API path or command/command directory path to be deleted from this role. Can be a resource-qualified endpoint (example: /api/svm/svms/43256a71-be02-474d-a2a9-9642e12a6a2c/top-metrics/users). Currently, resource-qualified endpoints are limited to the Snapshots, File System Analytics_, Artificial Intelligence Data Engine (AIDE)_ and ONTAP S3 endpoints listed above in the description.
  • security login rest-role delete
  • security login role delete
owner.uuid
string
path
True
Role owner UUID
name
string
path
True
Role name
path
string
path
True
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1263347
Cannot modify pre-defined roles.
5636168
This role is mapped to a REST role and can only be modified by updating the REST role.
5636169
Specified URI path is invalid or not supported. Resource-qualified endpoints are not supported.
5636170
URI does not exist.
5636172
User accounts detected with this role assigned. Update or delete those accounts before deleting this role.
5636173
This feature requires an effective cluster version of 9.6 or later.
5636184
Expanded REST roles for granular resource control feature is currently disabled.
5636185
The specified UUID was not found.
5636186
Expanded REST roles for granular resource control requires an effective cluster version of 9.10.1 or later.
5636259
The specified child AIDE object was not found within the specified parent AIDE object.
5636261
The specified grandchild AIDE object was not found within the specified child AIDE object that belongs to the specified parent AIDE object.
13434890
Vserver-ID failed for Vserver roles.
13434893
The SVM does not exist.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
