Delete a privilege tuple (of rest uri and its access level) from the role
name- name of the role to be updated -
path- constituent rest api path to be deleted from this role # related ontap commands -
security login rest-role delete# learn more -
doc /security/roles/{owneruuid}/{name}/privileges/{path}](#docs-security-security_roles_{owneruuid}_{name}_privileges_{path}) -
doc /security/roles](#docs-security-security_roles)
DELETE /security/roles/{owner.uuid}/{name}/privileges/{path}
Delete a privilege tuple (of REST URI and its access level) from the role.
Required parameters
owner.uuid- UUID of the SVM which houses this role. -
name- Name of the role to be updated. -
path- Constituent REST API path to be deleted from this role.
Related ONTAP commands
owner.uuid |
string |
path |
True |
name |
string |
path |
True |
path |
string |
path |
True |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5636173 |
Features requires an effective cluster version of 9.6 or later. |
5636172 |
User accounts detected with this role assigned. Modify/delete those accounts before deleting this role. |
13434893 |
SVM does not exist. |
13434890 |
Vserver-Id failed for Vserver roles. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
