Delete a privilege tuple from the role
Deletes a privilege tuple from a role, modifying its access permissions by removing the specified REST URI or command path. Use this when you need to update or restrict the capabilities associated with a role.
HTTP method and endpoint
DELETE /security/roles/{owner.uuid}/{name}/privileges/{path}
Introduced in
ONTAP 9.6
Usage notes
Deletes a privilege tuple (of REST URI or command/command directory path, its access level and an optional query) from the role. The REST URI can be a resource-qualified endpoint. Currently, the only supported resource-qualified endpoints are the following:
Snapshots APIs
– /api/storage/volumes/{volume.uuid}/snapshots
File System Analytics APIs
– /api/storage/volumes/{volume.uuid}/files
– /api/storage/volumes/{volume.uuid}/top-metrics/clients
– /api/storage/volumes/{volume.uuid}/top-metrics/directories
– /api/storage/volumes/{volume.uuid}/top-metrics/files
– /api/storage/volumes/{volume.uuid}/top-metrics/users
– /api/svm/svms/{svm.uuid}/top-metrics/clients
– /api/svm/svms/{svm.uuid}/top-metrics/directories
– /api/svm/svms/{svm.uuid}/top-metrics/files
– /api/svm/svms/{svm.uuid}/top-metrics/users
In the above APIs, wildcard character * could be used in place of {volume.uuid} or {svm.uuid} to denote all volumes or all SVMs, depending upon whether the REST endpoint references volumes or SVMs.
Required parameters
owner.uuid- UUID of the SVM which houses this role. -
name- Name of the role to be updated. -
path- Constituent REST API path or command/command directory path to be deleted from this role. Can be a resource-qualified endpoint (example: /api/svm/svms/43256a71-be02-474d-a2a9-9642e12a6a2c/top-metrics/users). Currently, resource-qualified endpoints are limited to the Snapshots and File System Analytics endpoints listed above in the description.
Related ONTAP commands
security login rest-role delete -
security login role delete
owner.uuid |
string |
path |
True |
Role owner UUID |
name |
string |
path |
True |
Role name |
path |
string |
path |
True |
REST API path or command/command directory path |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1263347 |
Cannot modify pre-defined roles. |
5636169 |
Specified URI path is invalid or not supported. Resource-qualified endpoints are not supported. |
5636170 |
URI does not exist. |
5636172 |
User accounts detected with this role assigned. Update or delete those accounts before deleting this role. |
5636173 |
This feature requires an effective cluster version of 9.6 or later. |
5636184 |
Expanded REST roles for granular resource control feature is currently disabled. |
5636185 |
The specified UUID was not found. |
5636186 |
Expanded REST roles for granular resource control requires an effective cluster version of 9.10.1 or later. |
13434890 |
Vserver-ID failed for Vserver roles. |
13434893 |
The SVM does not exist. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
