REST API reference
Delete a privilege tuple from the role
Removes a specific privilege tuple from a role, adjusting the permissions associated with that role in your ONTAP system. This action is used when you need to refine or update the access levels assigned to a role by deleting certain API paths or commands.
HTTP method and endpoint
DELETE /security/roles/{owner.uuid}/{name}/privileges/{path}
Introduced in
ONTAP 9.6
Usage notes
Deletes a privilege tuple (of REST URI or command/command directory path, its access level and an optional query) from the role. The REST URI can be a resource-qualified endpoint. Currently, the only supported resource-qualified endpoints are the following:
Snapshots APIs
– /api/storage/volumes/{volume.uuid}/snapshots
File System Analytics APIs
– /api/storage/volumes/{volume.uuid}/files
– /api/storage/volumes/{volume.uuid}/top-metrics/clients
– /api/storage/volumes/{volume.uuid}/top-metrics/directories
– /api/storage/volumes/{volume.uuid}/top-metrics/files
– /api/storage/volumes/{volume.uuid}/top-metrics/users
– /api/svm/svms/{svm.uuid}/top-metrics/clients
– /api/svm/svms/{svm.uuid}/top-metrics/directories
– /api/svm/svms/{svm.uuid}/top-metrics/files
– /api/svm/svms/{svm.uuid}/top-metrics/users
Ontap S3 APIs
– /api/protocols/s3/services/{svm.uuid}/users
In the above APIs, wildcard character * could be used in place of {volume.uuid} or {svm.uuid} to denote all volumes or all SVMs, depending upon whether the REST endpoint references volumes or SVMs. The {volume.uuid} refers to the -instance-uuid field value in the "volume show" command output at diagnostic privilege level. It can also be fetched through REST endpoint /api/storage/volumes.
Required parameters
  • owner.uuid - UUID of the SVM which houses this role.
  • name - Name of the role to be updated.
  • path - Constituent REST API path or command/command directory path to be deleted from this role. Can be a resource-qualified endpoint (example: /api/svm/svms/43256a71-be02-474d-a2a9-9642e12a6a2c/top-metrics/users). Currently, resource-qualified endpoints are limited to the Snapshots and File System Analytics endpoints listed above in the description.
  • security login rest-role delete
  • security login role delete
owner.uuid
string
path
True
Role owner UUID
name
string
path
True
Role name
path
string
path
True
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1263347
Cannot modify pre-defined roles.
5636168
This role is mapped to a rest-role and cannot be modified directly. Modifications must be done with rest-role.
5636169
Specified URI path is invalid or not supported. Resource-qualified endpoints are not supported.
5636170
URI does not exist.
5636172
User accounts detected with this role assigned. Update or delete those accounts before deleting this role.
5636173
This feature requires an effective cluster version of 9.6 or later.
5636184
Expanded REST roles for granular resource control feature is currently disabled.
5636185
The specified UUID was not found.
5636186
Expanded REST roles for granular resource control requires an effective cluster version of 9.10.1 or later.
13434890
Vserver-ID failed for Vserver roles.
13434893
The SVM does not exist.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
