REST API reference
Retrieve the NFS configuration for an SVM
Retrieves the NFS configuration for a storage virtual machine (SVM) to understand its current setup and manage NFS settings effectively.
HTTP method and endpoint
GET /protocols/nfs/connected-clients
Introduced in
ONTAP 9.7
Usage notes
Retrieves the NFS configuration of SVMs.
Expensive properties
export_policy.id is expensive field. It is not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • export_policy.id
export_policy.name
string
query
False
Filter by export_policy.name
  • Introduced in: 9.9
export_policy.id
integer
query
False
Filter by export_policy.id
volume.uuid
string
query
False
Filter by volume.uuid
volume.name
string
query
False
Filter by volume.name
server_ip
string
query
False
Filter by server_ip
node.uuid
string
query
False
Filter by node.uuid
node.name
string
query
False
Filter by node.name
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
idle_duration
string
query
False
Filter by idle_duration
protocol
string
query
False
Filter by protocol
remote_request_count
integer
query
False
Filter by remote_request_count
local_request_count
integer
query
False
Filter by local_request_count
client_ip
string
query
False
Filter by client_ip
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[nfs_clients]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "client_ip": "string",
      "export_policy": {
        "id": 100,
        "name": "default"
      "idle_duration": "P4DT84H30M5S",
      "node": {
        "name": "node1",
      "protocol": "nfs3",
      "server_ip": "string",
      "svm": {
        "name": "svm1",
      "volume": {
        "name": "volume1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
export_policy
Export Policy
_links
_links
id
integer
name
string
node
_links
_links
name
string
uuid
string
svm
_links
_links
name
string
The name of the SVM.
uuid
string
volume
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
nfs_clients
_links
_links
client_ip
string
Specifies IP address of the client.
export_policy
export_policy
Export Policy
idle_duration
string
Specifies an ISO-8601 format of date and time to retrieve the idle time duration in hours, minutes, and seconds format.
local_request_count
integer
A counter that tracks requests that are sent to the volume with fast-path to local node.
node
node
protocol
string
The NFS protocol version over which client is accessing the volume. The following values are supported:
  • nfs - All NFS versions are considered
  • nfs3 - NFS version 3 protocol
  • nfs4 - NFS version 4 protocol
  • nfs4.1 - NFS version 4 minor version 1 protocol
integer
A counter that tracks requests that are sent to the volume with slow-path to remote node.
server_ip
string
Specifies the IP address of the server.
svm
svm
volume
volume
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
