REST API reference
Retrieve NFS configuration for an SVM
Retrieves the NFS configuration for an SVM to understand its current settings and policies. This can help you manage and configure your storage environment effectively.
HTTP method and endpoint
GET /protocols/nfs/connected-clients
Introduced in
ONTAP 9.7
Usage notes
Retrieves the NFS configuration of SVMs.
Expensive properties
export_policy.id is expensive field. It is not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • export_policy.id
export_policy.name
string
query
False
Filter by export_policy.name
  • Introduced in: 9.9
export_policy.id
integer
query
False
Filter by export_policy.id
local_request_count
integer
query
False
Filter by local_request_count
client_ip
string
query
False
Filter by client_ip
volume.name
string
query
False
Filter by volume.name
volume.uuid
string
query
False
Filter by volume.uuid
node.name
string
query
False
Filter by node.name
node.uuid
string
query
False
Filter by node.uuid
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
server_ip
string
query
False
Filter by server_ip
idle_duration
string
query
False
Filter by idle_duration
remote_request_count
integer
query
False
Filter by remote_request_count
protocol
string
query
False
Filter by protocol
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[nfs_clients]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "client_ip": "string",
      "export_policy": {
        "id": "100",
        "name": "default"
      "idle_duration": "P4DT84H30M5S",
      "node": {
        "name": "node1",
      "protocol": "nfs3",
      "server_ip": "string",
      "svm": {
        "name": "svm1",
      "volume": {
        "name": "volume1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
export_policy
Export Policy
_links
_links
id
integer
name
string
node
_links
_links
name
string
uuid
string
svm
_links
_links
name
string
The name of the SVM.
uuid
string
volume
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
nfs_clients
_links
_links
client_ip
string
Specifies IP address of the client.
export_policy
export_policy
Export Policy
idle_duration
string
Specifies an ISO-8601 format of date and time to retrieve the idle time duration in hours, minutes, and seconds format.
local_request_count
integer
A counter that tracks requests that are sent to the volume with fast-path to local node.
node
node
protocol
string
The NFS protocol version over which client is accessing the volume. The following values are supported:
  • nfs - All NFS versions are considered
  • nfs3 - NFS version 3 protocol
  • nfs4 - NFS version 4 protocol
  • nfs4.1 - NFS version 4 minor version 1 protocol
integer
A counter that tracks requests that are sent to the volume with slow-path to remote node.
server_ip
string
Specifies the IP address of the server.
svm
svm
volume
volume
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
