REST API reference
Retrieve the NFS configuration for an SVM
GET /protocols/nfs/connected-clients
Introduced In: 9.7
Retrieves the NFS configuration of SVMs.
Expensive properties
export_policy.id is expensive field. It is not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • export_policy.id
volume.name
string
query
False
Filter by volume.name
volume.uuid
string
query
False
Filter by volume.uuid
client_ip
string
query
False
Filter by client_ip
trunking_enabled
boolean
query
False
Filter by trunking_enabled
  • Introduced in: 9.12
protocol
string
query
False
Filter by protocol
export_policy.name
string
query
False
Filter by export_policy.name
  • Introduced in: 9.9
export_policy.id
integer
query
False
Filter by export_policy.id
idle_duration
string
query
False
Filter by idle_duration
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
server_ip
string
query
False
Filter by server_ip
remote_request_count
integer
query
False
Filter by remote_request_count
node.name
string
query
False
Filter by node.name
node.uuid
string
query
False
Filter by node.uuid
local_request_count
integer
query
False
Filter by local_request_count
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[nfs_clients]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "client_ip": "string",
      "export_policy": {
        "id": 100,
        "name": "default"
      "idle_duration": "P4DT84H30M5S",
      "node": {
        "name": "node1",
      "protocol": "nfs3",
      "server_ip": "string",
      "svm": {
        "name": "svm1",
      "volume": {
        "name": "volume1",
Status: Default
ONTAP Error Response Codes
Error Code Description
917887
The first character of the volume name must be a letter or underscore.
917888
Invalid character in volume name. It can have '_' and alphanumeric characters.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
export_policy
Export Policy
_links
_links
id
integer
name
string
node
_links
_links
name
string
uuid
string
svm
_links
_links
name
string
uuid
string
volume
_links
_links
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
nfs_clients
_links
_links
client_ip
string
Specifies IP address of the client.
export_policy
export_policy
Export Policy
idle_duration
string
Specifies an ISO-8601 format of date and time to retrieve the idle time duration in hours, minutes, and seconds format.
local_request_count
integer
A counter that tracks requests that are sent to the volume with fast-path to local node.
node
node
protocol
string
The NFS protocol version over which client is accessing the volume. The following values are supported:
  • nfs - All NFS versions are considered
  • nfs3 - NFS version 3 protocol
  • nfs4 - NFS version 4 protocol
  • nfs4.1 - NFS version 4 minor version 1 protocol
  • nfs4.2 - NFS version 4 minor version 2 protocol
integer
A counter that tracks requests that are sent to the volume with slow-path to remote node.
server_ip
string
Specifies the IP address of the server.
svm
svm
trunking_enabled
boolean
Flag that indicates the trunking status for the specified SVM connection. True indicates that the trunking feature is enabled while false indicates that the trunking feature is disabled.
volume
volume
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
