Retrieve the NFS configuration for an SVM
GET /protocols/nfs/connected-clients
Introduced In: 9.7
Retrieves the NFS configuration of SVMs.
Expensive properties
export_policy.id is expensive field. It is not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
export_policy.id
local_request_count |
integer |
query |
False |
Filter by local_request_count |
node.uuid |
string |
query |
False |
Filter by node.uuid |
node.name |
string |
query |
False |
Filter by node.name |
export_policy.id |
integer |
query |
False |
Filter by export_policy.id
export_policy.name |
string |
query |
False |
Filter by export_policy.name
volume.uuid |
string |
query |
False |
Filter by volume.uuid |
volume.name |
string |
query |
False |
Filter by volume.name |
remote_request_count |
integer |
query |
False |
Filter by remote_request_count |
client_ip |
string |
query |
False |
Filter by client_ip |
server_ip |
string |
query |
False |
Filter by server_ip |
protocol |
string |
query |
False |
Filter by protocol |
idle_duration |
string |
query |
False |
Filter by idle_duration |
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
trunking_enabled |
boolean |
query |
False |
Filter by trunking_enabled
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[nfs_clients] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"client_ip": "string",
"export_policy": {
"id": 100,
"name": "default"
"idle_duration": "P4DT84H30M5S",
"node": {
"name": "node1",
"protocol": "nfs3",
"server_ip": "string",
"svm": {
"name": "svm1",
"volume": {
"name": "volume1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
917887 |
The first character of the volume name must be a letter or underscore. |
917888 |
Invalid character in volume name. It can have '_' and alphanumeric characters. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
export_policy
Export Policy
_links |
id |
integer |
name |
string |
node
_links |
name |
string |
uuid |
string |
svm
_links |
name |
string |
uuid |
string |
volume
_links |
name |
string |
The name of the volume. This field cannot be specified in a PATCH method. |
uuid |
string |
nfs_clients
_links |
client_ip |
string |
Specifies IP address of the client. |
export_policy |
Export Policy |
idle_duration |
string |
Specifies an ISO-8601 format of date and time to retrieve the idle time duration in hours, minutes, and seconds format. |
integer |
A counter that tracks requests that are sent to the volume with fast-path to local node. |
node |
protocol |
string |
The NFS protocol version over which client is accessing the volume. The following values are supported:
integer |
A counter that tracks requests that are sent to the volume with slow-path to remote node. |
server_ip |
string |
Specifies the IP address of the server. |
svm |
trunking_enabled |
boolean |
Flag that indicates the trunking status for the specified SVM connection. True indicates that the trunking feature is enabled while false indicates that the trunking feature is disabled. |
volume |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
