Retrieve NFS configuration for an SVM
Retrieves the NFS configuration for a specific SVM, gaining insight into the setup of NFS services within your storage environment. Use this endpoint to understand and manage NFS settings effectively for your storage virtual machines.
HTTP method and endpoint
GET /protocols/nfs/connected-clients
Introduced in
ONTAP 9.7
Usage notes
Retrieves the NFS configuration of SVMs.
Expensive properties
export_policy.id is expensive field. It is not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
export_policy.id
client_ip |
string |
query |
False |
Filter by client_ip |
node.uuid |
string |
query |
False |
Filter by node.uuid |
node.name |
string |
query |
False |
Filter by node.name |
idle_duration |
string |
query |
False |
Filter by idle_duration |
remote_request_count |
integer |
query |
False |
Filter by remote_request_count |
export_policy.id |
integer |
query |
False |
Filter by export_policy.id
export_policy.name |
string |
query |
False |
Filter by export_policy.name
volume.name |
string |
query |
False |
Filter by volume.name |
volume.uuid |
string |
query |
False |
Filter by volume.uuid |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
local_request_count |
integer |
query |
False |
Filter by local_request_count |
protocol |
string |
query |
False |
Filter by protocol |
server_ip |
string |
query |
False |
Filter by server_ip |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[nfs_clients] |
"next": {
"href": "/api/resourcelink"
"records": [
"client_ip": "string",
"export_policy": {
"id": 100,
"name": "default"
"idle_duration": "P4DT84H30M5S",
"node": {
"name": "node1",
"protocol": "nfs3",
"server_ip": "string",
"svm": {
"name": "svm1",
"volume": {
"name": "volume1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
export_policy
Export Policy
_links |
id |
integer |
name |
string |
node
_links |
name |
string |
uuid |
string |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
volume
_links |
name |
string |
The name of the volume. |
uuid |
string |
nfs_clients
_links |
client_ip |
string |
Specifies IP address of the client. |
export_policy |
Export Policy |
idle_duration |
string |
Specifies an ISO-8601 format of date and time to retrieve the idle time duration in hours, minutes, and seconds format. |
integer |
A counter that tracks requests that are sent to the volume with fast-path to local node. |
node |
protocol |
string |
The NFS protocol version over which client is accessing the volume. The following values are supported:
integer |
A counter that tracks requests that are sent to the volume with slow-path to remote node. |
server_ip |
string |
Specifies the IP address of the server. |
svm |
volume |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
