Retrieve IPsec CA certificates configured for the cluster and all SVMs
Retrieves the collection of IPsec CA certificates configured for the cluster and all SVMs to view the current certificate configuration across your environment.
HTTP method and endpoint
GET /security/ipsec/ca-certificates
Introduced in
ONTAP 9.10
Related ONTAP commands
security ipsec ca-certificate show
scope |
string |
query |
False |
Filter by scope |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
certificate.uuid |
string |
query |
False |
Filter by certificate.uuid |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[ipsec_ca_certificate] |
"next": {
"href": "/api/resourcelink"
"records": [
"certificate": {
"scope": "string",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
certificate
IPsec CA certificate UUID
_links |
uuid |
string |
Certificate UUID |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
certificate |
IPsec CA certificate UUID |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
