REST API reference
Retrieve IPsec CA certificates configured for the cluster and all SVMs
Retrieves the IPsec CA certificates configured for your cluster and all SVMs to review the existing security certificate configuration.
HTTP method and endpoint
GET /security/ipsec/ca-certificates
Introduced in
ONTAP 9.10
Usage notes
Retrieves the collection of IPsec CA certificates configured for cluster and all SVMs.
  • security ipsec ca-certificate show
certificate.uuid
string
query
False
Filter by certificate.uuid
scope
string
query
False
Filter by scope
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[ipsec_ca_certificate]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "certificate": {
      "scope": "string",
      "svm": {
        "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
certificate
IPsec CA certificate UUID
_links
_links
uuid
string
Certificate UUID
svm
_links
_links
name
string
The name of the SVM.
uuid
string
certificate
certificate
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
