Retrieve IPsec CA certificates configured for the cluster and all SVMs
Accesses the collection of IPsec CA certificates configured for the cluster and all SVMs. This helps you manage and verify the security certificates used for IPsec communications within your network.
HTTP method and endpoint
GET /security/ipsec/ca-certificates
Introduced in
ONTAP 9.10
Usage notes
Retrieves the collection of IPsec CA certificates configured for cluster and all SVMs.
Related ONTAP commands
security ipsec ca-certificate show
certificate.uuid |
string |
query |
False |
Filter by certificate.uuid |
scope |
string |
query |
False |
Filter by scope |
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[ipsec_ca_certificate] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"certificate": {
"scope": "string",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
certificate
IPsec CA certificate UUID
_links |
uuid |
string |
Certificate UUID |
svm
_links |
name |
string |
uuid |
string |
certificate |
IPsec CA certificate UUID |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
