Retrieve IPsec CA certificates configured for the cluster and all SVMs
Retrieves the collection of IPsec CA certificates configured for the cluster and all SVMs to ensure secure communications within your network environment.
HTTP method and endpoint
GET /security/ipsec/ca-certificates
Introduced in
ONTAP 9.10
Related ONTAP commands
security ipsec ca-certificate show
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
scope |
string |
query |
False |
Filter by scope |
certificate.uuid |
string |
query |
False |
Filter by certificate.uuid |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[ipsec_ca_certificate] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"certificate": {
"scope": "string",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
certificate
IPsec CA certificate UUID
_links |
uuid |
string |
Certificate UUID |
svm
_links |
name |
string |
uuid |
string |
certificate |
IPsec CA certificate UUID |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
