Retrieve IPsec CA certificates configured for the cluster and all SVMs
Accesses the collection of IPsec CA certificates configured for both the cluster and all SVMs to review the security configurations associated with these certificates.
HTTP method and endpoint
GET /security/ipsec/ca-certificates
Introduced in
ONTAP 9.10
Usage notes
Retrieves the collection of IPsec CA certificates configured for cluster and all SVMs.
Related ONTAP commands
security ipsec ca-certificate show
scope |
string |
query |
False |
Filter by scope |
certificate.uuid |
string |
query |
False |
Filter by certificate.uuid |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[ipsec_ca_certificate] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"certificate": {
"scope": "string",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
certificate
IPsec CA certificate UUID
_links |
uuid |
string |
Certificate UUID |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
certificate |
IPsec CA certificate UUID |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
