Retrieve keystores
Retrieves keystores to access and manage the stored security keys necessary for your ONTAP system's operations. Explicitly request additional properties if needed for more detailed information.
HTTP method and endpoint
GET /security/key-stores
Introduced in
ONTAP 9.10
Expensive properties
There is an added cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
keystore.location -
svm.name -
svm.uuid
Related ONTAP commands
security key-manager show-key-store
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
type |
string |
query |
False |
Filter by type |
uuid |
string |
query |
False |
Filter by uuid |
location |
string |
query |
False |
Filter by location |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[security_keystore] |
"next": {
"href": "/api/resourcelink"
"records": [
"location": "string",
"svm": {
"name": "svm1",
"type": "string",
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
security_keystore
location |
string |
Indicates whether the keystore is onboard or external. |
svm |
type |
string |
Type of keystore that is configured: * 'okm' - Onboard Key Manager * 'kmip' - External Key Manager * 'akv' - Azure Key Vault Key Management Service * 'gcp' - Google Cloud Platform Key Management Service * 'aws' - Amazon Web Service Key Management Service |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
