REST API reference
Retrieve keystores
Retrieves keystores to access information about the keys stored within your system, which is useful for managing security and encryption settings.
HTTP method and endpoint
GET /security/key-stores
Introduced in
ONTAP 9.10
  • security key-manager show-key-store
  • security key-manager keystore show
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
uuid
string
query
False
Filter by uuid
type
string
query
False
Filter by type
scope
string
query
False
Filter by scope
  • Introduced in: 9.14
state
string
query
False
Filter by state
  • Introduced in: 9.16
location
string
query
False
Filter by location
enabled
boolean
query
False
Filter by enabled
configuration.uuid
string
query
False
Filter by configuration.uuid
configuration.name
string
query
False
Filter by configuration.name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records.
records
array[security_keystore]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "configuration": {
        "name": "default",
        "uuid": "1cd8a442-86d1-11e0-ae1c-123478563434"
      "location": "string",
      "scope": "string",
      "state": "string",
      "svm": {
        "name": "svm1",
      "type": "string",
      "uuid": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
13434920
SVM does not exist.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
configuration
Security keystore object reference.
_links
_links
name
string
Name of the configuration.
uuid
string
Keystore UUID.
svm
_links
_links
name
string
uuid
string
security_keystore
configuration
configuration
enabled
boolean
Indicates whether the configuration is enabled.
location
string
Indicates whether the keystore is onboard or external. * 'onboard' - Onboard Key Database * 'external' - External Key Database, including KMIP and Cloud Key Management Systems
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
state
string
State of the keystore: * 'active' - The key manager is active and serving new and existing keys. * 'mixed' - The key manager has a mixed configuration. New keys can't be created. * 'svm_kek_rekey' - An SVM key encryption key (KEK) rekey is in progress. New keys can't be created. * 'blocked' - The key manager is blocked and cannot serve new and existing keys. * 'switching' - Switching the enabled key manager keystore configuration. Some operations are blocked. * 'initializing' - The key manager is being initialized. All operations are blocked. * 'disabling' - The key manager is being disabled. All operations are blocked.
svm
svm
type
string
Type of keystore that is configured: * 'okm' - Onboard Key Manager * 'kmip' - External Key Manager * 'akv' - Azure Key Vault Key Management Service * 'gcp' - Google Cloud Platform Key Management Service * 'aws' - Amazon Web Service Key Management Service * 'ikp' - IBM Key Protect Key Management Service
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
