Retrieve keystores
Retrieves keystores to access information about stored keys, which can assist in managing and securing encryption keys within your storage environment.
HTTP method and endpoint
GET /security/key-stores
Introduced in
ONTAP 9.10
Related ONTAP commands
security key-manager show-key-store -
security key-manager keystore show
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
location |
string |
query |
False |
Filter by location |
enabled |
boolean |
query |
False |
Filter by enabled
configuration.name |
string |
query |
False |
Filter by configuration.name
configuration.uuid |
string |
query |
False |
Filter by configuration.uuid
scope |
string |
query |
False |
Filter by scope
type |
string |
query |
False |
Filter by type |
state |
string |
query |
False |
Filter by state
uuid |
string |
query |
False |
Filter by uuid |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[security_keystore] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"configuration": {
"name": "default",
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563434"
"location": "string",
"scope": "string",
"state": "string",
"svm": {
"name": "svm1",
"type": "string",
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
13434920 |
SVM does not exist. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
configuration
Security keystore object reference.
_links |
name |
string |
Name of the configuration. |
uuid |
string |
Keystore UUID. |
svm
_links |
name |
string |
uuid |
string |
security_keystore
configuration |
Security keystore object reference. |
enabled |
boolean |
Indicates whether the configuration is enabled. |
location |
string |
Indicates whether the keystore is onboard or external. * 'onboard' - Onboard Key Database * 'external' - External Key Database, including KMIP and Cloud Key Management Systems |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
state |
string |
State of the keystore: * 'active' - The key manager is active and serving new and existing keys. * 'mixed' - The key manager has a mixed configuration. New keys can't be created. * 'svm_kek_rekey' - An SVM key encryption key (KEK) rekey is in progress. New keys can't be created. * 'blocked' - The key manager is blocked and cannot serve new and existing keys. * 'switching' - Switching the enabled key manager keystore configuration. Some operations are blocked. * 'initializing' - The key manager is being initialized. All operations are blocked. * 'disabling' - The key manager is being disabled. All operations are blocked. |
svm |
type |
string |
Type of keystore that is configured: * 'okm' - Onboard Key Manager * 'kmip' - External Key Manager * 'akv' - Azure Key Vault Key Management Service * 'gcp' - Google Cloud Platform Key Management Service * 'aws' - Amazon Web Service Key Management Service * 'ikp' - IBM Key Protect Key Management Service * 'barbican' - Barbican Key Management Service |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
