Retrieve keystores
Retrieves keystores to access and manage the storage of encryption keys within your environment. This functionality is essential for ensuring secure data handling and compliance with encryption standards.
HTTP method and endpoint
GET /security/key-stores
Introduced in
ONTAP 9.10
Related ONTAP commands
security key-manager show-key-store -
security key-manager keystore show
configuration.name |
string |
query |
False |
Filter by configuration.name
configuration.uuid |
string |
query |
False |
Filter by configuration.uuid
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
scope |
string |
query |
False |
Filter by scope
enabled |
boolean |
query |
False |
Filter by enabled
type |
string |
query |
False |
Filter by type |
location |
string |
query |
False |
Filter by location |
uuid |
string |
query |
False |
Filter by uuid |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[security_keystore] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"configuration": {
"name": "default",
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563434"
"location": "string",
"scope": "string",
"svm": {
"name": "svm1",
"type": "string",
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
13434920 |
SVM does not exist. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
configuration
Security keystore object reference.
_links |
name |
string |
Name of the configuration. |
uuid |
string |
Keystore UUID. |
svm
_links |
name |
string |
uuid |
string |
security_keystore
configuration |
Security keystore object reference. |
enabled |
boolean |
Indicates whether the configuration is enabled. |
location |
string |
Indicates whether the keystore is onboard or external. * 'onboard' - Onboard Key Database * 'external' - External Key Database, including KMIP and Cloud Key Management Systems |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
svm |
type |
string |
Type of keystore that is configured: * 'okm' - Onboard Key Manager * 'kmip' - External Key Manager * 'akv' - Azure Key Vault Key Management Service * 'gcp' - Google Cloud Platform Key Management Service * 'aws' - Amazon Web Service Key Management Service * 'ikp' - IBM Key Protect Key Management Service |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
