REST API reference
Retrieve keystores
Retrieves keystore information to access details about secure storage configurations. Use this endpoint to obtain specific keystore properties, which are necessary for managing security settings effectively.
HTTP method and endpoint
GET /security/key-stores
Introduced in
ONTAP 9.10
Usage notes
Retrieves keystores.
Expensive properties
There is an added cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • keystore.location
  • svm.name
  • svm.uuid
  • security key-manager show-key-store
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
location
string
query
False
Filter by location
type
string
query
False
Filter by type
uuid
string
query
False
Filter by uuid
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records.
records
array[security_keystore]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "location": "string",
      "svm": {
        "name": "svm1",
      "type": "string",
      "uuid": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
security_keystore
location
string
Indicates whether the keystore is onboard or external.
svm
svm
type
string
Type of keystore that is configured: * 'okm' - Onboard Key Manager * 'kmip' - External Key Manager * 'akv' - Azure Key Vault Key Management Service * 'gcp' - Google Cloud Platform Key Management Service * 'aws' - Amazon Web Service Key Management Service
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
