Retrieves flexcache in the cluster
originsip_address- ip address of origin -
originssize- physical size of origin -
originsstate- state of origin -
size- physical size of flexcache -
guaranteetype- space guarantee style of flexcache -
aggregatesnameoraggregatesuuid- name or uuid of aggregrate of flexcache volume -
path- fully-qualified path of the owning svms namespace where the flexcache is mounted # related ontap commands -
volume flexcache show# learn more -
doc /storage/flexcache/flexcaches](#docs-storage-storage_flexcache_flexcaches)
GET /storage/flexcache/flexcaches
Introduced In: 9.6
Retrieves FlexCache in the cluster.
Expensive properties
There is an added cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
origins.ip_address- IP address of origin. -
origins.size- Physical size of origin. -
origins.state- State of origin. -
size- Physical size of FlexCache. -
guarantee.type- Space guarantee style of FlexCache. -
aggregates.nameoraggregates.uuid- Name or UUID of aggregrate of FlexCache volume. -
path- Fully-qualified path of the owning SVM's namespace where the FlexCache is mounted.
Related ONTAP commands
Learn more
guarantee.type |
string |
query |
False |
Filter by guarantee.type
size |
integer |
query |
False |
Filter by size |
global_file_locking_enabled |
boolean |
query |
False |
Filter by global_file_locking_enabled
constituents_per_aggregate |
integer |
query |
False |
Filter by constituents_per_aggregate |
name |
string |
query |
False |
Filter by name |
aggregates.uuid |
string |
query |
False |
Filter by aggregates.uuid |
aggregates.name |
string |
query |
False |
Filter by aggregates.name |
uuid |
string |
query |
False |
Filter by uuid |
dr_cache |
boolean |
query |
False |
Filter by dr_cache
path |
string |
query |
False |
Filter by path |
origins.volume.name |
string |
query |
False |
Filter by origins.volume.name |
origins.volume.uuid |
string |
query |
False |
Filter by origins.volume.uuid |
origins.create_time |
string |
query |
False |
Filter by origins.create_time |
origins.svm.uuid |
string |
query |
False |
Filter by origins.svm.uuid |
origins.svm.name |
string |
query |
False |
Filter by origins.svm.name |
origins.state |
string |
query |
False |
Filter by origins.state |
origins.ip_address |
string |
query |
False |
Filter by origins.ip_address |
origins.cluster.uuid |
string |
query |
False |
Filter by origins.cluster.uuid |
origins.cluster.name |
string |
query |
False |
Filter by origins.cluster.name |
origins.size |
integer |
query |
False |
Filter by origins.size |
use_tiered_aggregate |
boolean |
query |
False |
Filter by use_tiered_aggregate
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
return_timeout |
integer |
query |
False |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
order_by |
array[string] |
query |
False |
desc] direction. Default direction is 'asc' for ascending. |
return_records |
boolean |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[flexcache] |
"next": {
"href": "/api/resourcelink"
"records": [
"aggregates": [
"name": "aggr1",
"guarantee": {
"type": "string"
"name": "vol1",
"origins": [
"cluster": {
"name": "cluster1",
"create_time": "2018-06-04T19:00:00Z",
"ip_address": "10.10.10.7",
"size": 0,
"state": "string",
"svm": {
"name": "svm1",
"volume": {
"name": "volume1",
"path": "/user/my_fc",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
aggregates
Aggregate
_links |
name |
string |
uuid |
string |
guarantee
type |
string |
The type of space guarantee of this volume in the aggregate. |
cluster
_links |
name |
string |
uuid |
string |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
volume
_links |
name |
string |
The name of the volume. |
uuid |
string |
flexcache_relationship
cluster |
create_time |
string |
Creation time of the relationship. |
ip_address |
string |
Cluster managerment IP of the remote cluster. |
size |
integer |
Size of the remote volume. |
state |
string |
Volume state |
svm |
volume |
prepopulate
FlexCache prepopulate
svm
FlexCache SVM
_links |
name |
string |
uuid |
string |
flexcache
Defines the cache endpoint of FlexCache.
_links |
aggregates |
array[aggregates] |
integer |
Number of FlexCache constituents per aggregate when the 'aggregates' field is mentioned. |
dr_cache |
boolean |
If set to true, a DR cache is created. |
boolean |
Specifies whether or not a FlexCache volume has global file locking mode enabled. Global file locking mode is a mode where protocol read locking semantics are enforced across all FlexCaches and origins of a FlexCache volume. When global file locking mode is enabled, the "is_disconnected_mode_off_for_locks" flag is always set to "true". |
guarantee |
name |
string |
FlexCache name |
origins |
array[flexcache_relationship] |
path |
string |
The fully-qualified path in the owning SVM's namespace at which the FlexCache is mounted. The path is case insensitive and must be unique within a SVM's namespace. Path must begin with '/' and must not end with '/'. Only one FlexCache be mounted at any given junction path. |
size |
integer |
Physical size of the FlexCache. The recommended size for a FlexCache is 10% of the origin volume. The minimum FlexCache constituent size is 1GB. |
svm |
FlexCache SVM |
boolean |
Specifies whether or not a Fabricpool-enabled aggregate can be used in FlexCache creation. The use_tiered_aggregate is only used when auto-provisioning a FlexCache volume. |
uuid |
string |
FlexCache UUID. Unique identifier for the FlexCache. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
