REST API reference
Retrieve a FlexCache volume in the cluster
Retrieves a FlexCache volume in the cluster to access its configuration and properties for storage management tasks.
HTTP method and endpoint
GET /storage/flexcache/flexcaches
Introduced in
ONTAP 9.6
Usage notes
Retrieves FlexCache in the cluster.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • origins.ip_address - IP address of origin.
  • origins.size - Physical size of origin.
  • origins.state - State of origin.
  • size - Physical size of FlexCache.
  • guarantee.type - Space guarantee style of FlexCache.
  • aggregates.name or aggregates.uuid - Name or UUID of aggregrate of FlexCache volume.
  • path - Fully-qualified path of the owning SVM's namespace where the FlexCache is mounted.
  • volume flexcache show
override_encryption
boolean
query
False
Filter by override_encryption
  • Introduced in: 9.14
atime_scrub.enabled
boolean
query
False
Filter by atime_scrub.enabled
atime_scrub.period
integer
query
False
Filter by atime_scrub.period
origins.svm.uuid
string
query
False
Filter by origins.svm.uuid
origins.svm.name
string
query
False
Filter by origins.svm.name
origins.create_time
string
query
False
Filter by origins.create_time
origins.ip_address
string
query
False
Filter by origins.ip_address
origins.size
integer
query
False
Filter by origins.size
origins.cluster.uuid
string
query
False
Filter by origins.cluster.uuid
origins.cluster.name
string
query
False
Filter by origins.cluster.name
origins.volume.name
string
query
False
Filter by origins.volume.name
origins.volume.uuid
string
query
False
Filter by origins.volume.uuid
origins.state
string
query
False
Filter by origins.state
constituents_per_aggregate
integer
query
False
Filter by constituents_per_aggregate
path
string
query
False
Filter by path
name
string
query
False
Filter by name
  • maxLength: 203
  • minLength: 1
dr_cache
boolean
query
False
Filter by dr_cache
  • Introduced in: 9.9
guarantee.type
string
query
False
Filter by guarantee.type
  • Introduced in: 9.7
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
global_file_locking_enabled
boolean
query
False
Filter by global_file_locking_enabled
size
integer
query
False
Filter by size
uuid
string
query
False
Filter by uuid
writeback.enabled
boolean
query
False
Filter by writeback.enabled
  • Introduced in: 9.12
use_tiered_aggregate
boolean
query
False
Filter by use_tiered_aggregate
  • Introduced in: 9.8
relative_size.enabled
boolean
query
False
Filter by relative_size.enabled
  • Introduced in: 9.13
relative_size.percentage
integer
query
False
Filter by relative_size.percentage
cifs_change_notify.enabled
boolean
query
False
Filter by cifs_change_notify.enabled
aggregates.uuid
string
query
False
Filter by aggregates.uuid
aggregates.name
string
query
False
Filter by aggregates.name
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
order_by
array[string]
query
False
desc] direction. Default direction is 'asc' for ascending.
return_records
boolean
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[flexcache]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "aggregates": [
          "name": "aggr1",
      "guarantee": {
        "type": "string"
      "name": "vol1",
      "origins": [
          "cluster": {
            "name": "cluster1",
          "create_time": "2018-06-04 15:00:00 -0400",
          "ip_address": "10.10.10.7",
          "size": 0,
          "state": "string",
          "svm": {
            "name": "svm1",
          "volume": {
            "name": "volume1",
      "path": "/user/my_fc",
      "svm": {
        "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
aggregates
Aggregate
_links
_links
name
string
uuid
string
atime_scrub
FlexCache volume atime-based scrub
enabled
boolean
Specifies whether scrubbing of inactive files based on atime is enabled for the FlexCache volume. When scrubbing is enabled, files whose atime is older than the specified duration are evicted from the cache volume. The scrubber runs once a day and looks for files whose atime has exceeded the provisioned value.
period
integer
Specifies the atime duration in days after which a cached file is considered inactive. Inactive files are purged from the FlexCache volumes when the scrubber runs once a day.
cifs_change_notify
Notifies that a change has been made to the FlexCache volume CIFS.
enabled
boolean
Specifies whether a CIFS change notification is enabled for the FlexCache volume.
guarantee
type
string
The type of space guarantee of this volume in the aggregate.
cluster
_links
_links
name
string
uuid
string
svm
_links
_links
name
string
uuid
string
volume
_links
_links
name
string
The name of the volume. This field cannot be specified in a POST or PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
flexcache_relationship
cluster
cluster
create_time
string
Creation time of the relationship.
ip_address
string
Cluster managerment IP of the remote cluster.
size
integer
Size of the remote volume.
state
string
Volume state
svm
svm
volume
volume
prepopulate
FlexCache prepopulate
relative_size
FlexCache Relative Size
enabled
boolean
Specifies whether the relative sizing is enabled for the FlexCache volume. Relative sizing is introduced as a part of follow the origin feature. When relative sizing is enabled, it blocks any modifications done manually in the absolute size of the FlexCache volume. The size of the FlexCache volume is calculated and entered automatically based on the size of the origin volume.
percentage
integer
Specifies the percent size the FlexCache volume should have relative to the total size of the origin volume. This property is only relevant to a FlexCache volume that has the relative size property enabled.
svm
FlexCache SVM
_links
_links
name
string
uuid
string
writeback
FlexCache Writeback
enabled
boolean
Indicates whether or not writeback is enabled for the FlexCache volume. Writeback is a storage method where data is first written to the FlexCache volume and then written to the origin of a FlexCache volume.
flexcache
Defines the cache endpoint of FlexCache.
_links
_links
aggregates
array[aggregates]
atime_scrub
atime_scrub
cifs_change_notify
cifs_change_notify
integer
Number of FlexCache constituents per aggregate when the 'aggregates' field is mentioned.
dr_cache
boolean
If set to true, a DR cache is created.
boolean
Specifies whether or not a FlexCache volume has global file locking mode enabled. Global file locking mode is a mode where protocol read locking semantics are enforced across all FlexCaches and origins of a FlexCache volume. When global file locking mode is enabled, the "is_disconnected_mode_off_for_locks" flag is always set to "true".
guarantee
guarantee
name
string
FlexCache name
origins
array[flexcache_relationship]
override_encryption
boolean
If set to true, a plaintext FlexCache volume for an encrypted origin volume is created.
path
string
The fully-qualified path in the owning SVM's namespace at which the FlexCache is mounted. The path is case insensitive and must be unique within a SVM's namespace. Path must begin with '/' and must not end with '/'. Only one FlexCache be mounted at any given junction path.
relative_size
relative_size
size
integer
Physical size of the FlexCache. The recommended size for a FlexCache is 10% of the origin volume. The minimum FlexCache constituent size is 1GB.
svm
svm
FlexCache SVM
boolean
Specifies whether or not a Fabricpool-enabled aggregate can be used in FlexCache creation. The use_tiered_aggregate is only used when auto-provisioning a FlexCache volume.
uuid
string
FlexCache UUID. Unique identifier for the FlexCache.
writeback
writeback
FlexCache Writeback
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
