REST API reference
Retrieves flexcache in the cluster
  • originsip_address - ip address of origin
  • originssize - physical size of origin
  • originsstate - state of origin
  • size - physical size of flexcache
  • guaranteetype - space guarantee style of flexcache
  • aggregatesname or aggregatesuuid - name or uuid of aggregrate of flexcache volume
  • path - fully-qualified path of the owning svms namespace where the flexcache is mounted # related ontap commands
  • volume flexcache show # learn more
  • [doc /storage/flexcache/flexcaches](#docs-storage-storage_flexcache_flexcaches)
GET /storage/flexcache/flexcaches
Introduced In: 9.6
Retrieves FlexCache in the cluster.
Expensive properties
There is an added cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • origins.ip_address - IP address of origin.
  • origins.size - Physical size of origin.
  • origins.state - State of origin.
  • size - Physical size of FlexCache.
  • guarantee.type - Space guarantee style of FlexCache.
  • aggregates.name or aggregates.uuid - Name or UUID of aggregrate of FlexCache volume.
  • path - Fully-qualified path of the owning SVM's namespace where the FlexCache is mounted.
dr_cache
boolean
query
False
Filter by dr_cache
  • Introduced in: 9.9
aggregates.uuid
string
query
False
Filter by aggregates.uuid
aggregates.name
string
query
False
Filter by aggregates.name
path
string
query
False
Filter by path
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
uuid
string
query
False
Filter by uuid
size
integer
query
False
Filter by size
name
string
query
False
Filter by name
global_file_locking_enabled
boolean
query
False
Filter by global_file_locking_enabled
guarantee.type
string
query
False
Filter by guarantee.type
  • Introduced in: 9.7
origins.svm.name
string
query
False
Filter by origins.svm.name
origins.svm.uuid
string
query
False
Filter by origins.svm.uuid
origins.volume.uuid
string
query
False
Filter by origins.volume.uuid
origins.volume.name
string
query
False
Filter by origins.volume.name
origins.cluster.uuid
string
query
False
Filter by origins.cluster.uuid
origins.cluster.name
string
query
False
Filter by origins.cluster.name
origins.ip_address
string
query
False
Filter by origins.ip_address
origins.create_time
string
query
False
Filter by origins.create_time
origins.size
integer
query
False
Filter by origins.size
origins.state
string
query
False
Filter by origins.state
use_tiered_aggregate
boolean
query
False
Filter by use_tiered_aggregate
  • Introduced in: 9.8
constituents_per_aggregate
integer
query
False
Filter by constituents_per_aggregate
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
order_by
array[string]
query
False
desc] direction. Default direction is 'asc' for ascending.
return_records
boolean
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[flexcache]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "aggregates": [
          "name": "aggr1",
      "guarantee": {
        "type": "string"
      "name": "vol1",
      "origins": [
          "cluster": {
            "name": "cluster1",
          "create_time": "2018-06-04T19:00:00Z",
          "ip_address": "10.10.10.7",
          "size": 0,
          "state": "string",
          "svm": {
            "name": "svm1",
          "volume": {
            "name": "volume1",
      "path": "/user/my_fc",
      "svm": {
        "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
aggregates
Aggregate
_links
_links
name
string
uuid
string
guarantee
type
string
The type of space guarantee of this volume in the aggregate.
cluster
_links
_links
name
string
uuid
string
svm
_links
_links
name
string
The name of the SVM.
uuid
string
volume
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
flexcache_relationship
cluster
cluster
create_time
string
Creation time of the relationship.
ip_address
string
Cluster managerment IP of the remote cluster.
size
integer
Size of the remote volume.
state
string
Volume state
svm
svm
volume
volume
prepopulate
FlexCache prepopulate
svm
FlexCache SVM
_links
_links
name
string
uuid
string
flexcache
Defines the cache endpoint of FlexCache.
_links
_links
aggregates
array[aggregates]
integer
Number of FlexCache constituents per aggregate when the 'aggregates' field is mentioned.
dr_cache
boolean
If set to true, a DR cache is created.
boolean
Specifies whether or not a FlexCache volume has global file locking mode enabled. Global file locking mode is a mode where protocol read locking semantics are enforced across all FlexCaches and origins of a FlexCache volume.
guarantee
guarantee
name
string
FlexCache name
origins
array[flexcache_relationship]
path
string
The fully-qualified path in the owning SVM's namespace at which the FlexCache is mounted. The path is case insensitive and must be unique within a SVM's namespace. Path must begin with '/' and must not end with '/'. Only one FlexCache be mounted at any given junction path.
size
integer
Physical size of the FlexCache. The recommended size for a FlexCache is 10% of the origin volume. The minimum FlexCache constituent size is 1GB.
svm
svm
FlexCache SVM
boolean
Specifies whether or not a Fabricpool-enabled aggregate can be used in FlexCache creation. The use_tiered_aggregate is only used when auto-provisioning a FlexCache volume.
uuid
string
FlexCache UUID. Unique identifier for the FlexCache.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
