Retrieve a FlexCache volume in the cluster
Retrieves a FlexCache volume in the cluster to gain insights into its configuration and status. Use this information to manage your storage resources effectively.
HTTP method and endpoint
GET /storage/flexcache/flexcaches
Introduced in
ONTAP 9.6
Usage notes
Retrieves FlexCache in the cluster.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
origins.ip_address- IP address of origin. -
origins.size- Physical size of origin. -
origins.state- State of origin. -
size- Physical size of FlexCache. -
guarantee.type- Space guarantee style of FlexCache. -
aggregates.nameoraggregates.uuid- Name or UUID of aggregate of FlexCache volume. -
path- Fully-qualified path of the owning SVM's namespace where the FlexCache is mounted.
Related ONTAP commands
volume flexcache show
Learn more
relative_size.enabled |
boolean |
query |
False |
Filter by relative_size.enabled
relative_size.percentage |
integer |
query |
False |
Filter by relative_size.percentage
origins.state |
string |
query |
False |
Filter by origins.state |
origins.svm.uuid |
string |
query |
False |
Filter by origins.svm.uuid |
origins.svm.name |
string |
query |
False |
Filter by origins.svm.name |
origins.size |
integer |
query |
False |
Filter by origins.size |
origins.volume.name |
string |
query |
False |
Filter by origins.volume.name |
origins.volume.uuid |
string |
query |
False |
Filter by origins.volume.uuid |
origins.cluster.uuid |
string |
query |
False |
Filter by origins.cluster.uuid |
origins.cluster.name |
string |
query |
False |
Filter by origins.cluster.name |
origins.create_time |
string |
query |
False |
Filter by origins.create_time |
origins.ip_address |
string |
query |
False |
Filter by origins.ip_address |
size |
integer |
query |
False |
Filter by size |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
cifs.enabled |
boolean |
query |
False |
Filter by cifs.enabled
name |
string |
query |
False |
Filter by name
mtime_scrubber.threshold |
integer |
query |
False |
Filter by mtime_scrubber.threshold
mtime_scrubber.enabled |
boolean |
query |
False |
Filter by mtime_scrubber.enabled
atime_scrub.enabled |
boolean |
query |
False |
Filter by atime_scrub.enabled
atime_scrub.period |
integer |
query |
False |
Filter by atime_scrub.period
dr_cache |
boolean |
query |
False |
Filter by dr_cache
nfsv4.enabled |
boolean |
query |
False |
Filter by nfsv4.enabled
global_file_locking_enabled |
boolean |
query |
False |
Filter by global_file_locking_enabled
path |
string |
query |
False |
Filter by path |
use_tiered_aggregate |
boolean |
query |
False |
Filter by use_tiered_aggregate
guarantee.type |
string |
query |
False |
Filter by guarantee.type
cifs_change_notify.enabled |
boolean |
query |
False |
Filter by cifs_change_notify.enabled
aggregates.uuid |
string |
query |
False |
Filter by aggregates.uuid |
aggregates.name |
string |
query |
False |
Filter by aggregates.name |
writeback.enabled |
boolean |
query |
False |
Filter by writeback.enabled
constituents_per_aggregate |
integer |
query |
False |
Filter by constituents_per_aggregate |
s3.enabled |
boolean |
query |
False |
Filter by s3.enabled
write.absorption_enabled |
boolean |
query |
False |
Filter by write.absorption_enabled
uuid |
string |
query |
False |
Filter by uuid |
override_encryption |
boolean |
query |
False |
Filter by override_encryption
return_timeout |
integer |
query |
False |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
order_by |
array[string] |
query |
False |
desc] direction. Default direction is 'asc' for ascending. |
return_records |
boolean |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[flexcache] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"aggregates": [
"name": "aggr1",
"constituents_per_aggregate": 1,
"guarantee": {
"type": "string"
"name": "vol1",
"origins": [
"cluster": {
"name": "cluster1",
"create_time": "2018-06-04 19:00:00 +0000",
"ip_address": "10.10.10.7",
"size": 0,
"state": "string",
"svm": {
"name": "svm1",
"volume": {
"name": "volume1",
"path": "/user/my_fc",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
aggregates
Aggregate
_links |
name |
string |
uuid |
string |
atime_scrub
FlexCache volume atime-based scrub
enabled |
boolean |
Specifies whether scrubbing of inactive files based on atime is enabled for the FlexCache volume. When scrubbing is enabled, files whose atime is older than the specified duration are evicted from the cache volume. The scrubber runs once a day and looks for files whose atime has exceeded the provisioned value. |
period |
integer |
Specifies the atime duration in days after which a cached file is considered inactive. Inactive files are purged from the FlexCache volumes when the scrubber runs once a day. |
cifs
FlexCache CIFS
enabled |
boolean |
Specifies whether CIFS access is enabled on the FlexCache volume. |
cifs_change_notify
Notifies that a change has been made to the FlexCache volume CIFS.
enabled |
boolean |
Specifies whether a CIFS change notification is enabled for the FlexCache volume. |
guarantee
type |
string |
The type of space guarantee of this volume in the aggregate. |
mtime_scrubber
Flexcache Mtime Scrubber
enabled |
boolean |
Indicates whether mtime-based scrubber is enabled on the FlexCache volume. The mtime scrubber automatically scrubs files from the cache based on their modification time. |
threshold |
integer |
Specifies the mtime threshold in seconds. Files that have not been modified within this threshold duration are eligible for scrubbing from the FlexCache volume. Valid range is 900 to 86400 seconds (15 minutes to 24 hours). |
nfsv4
FlexCache NFSv4
enabled |
boolean |
Specifies whether NFSv4 access is enabled on the FlexCache volume. |
cluster
_links |
name |
string |
uuid |
string |
svm
_links |
name |
string |
uuid |
string |
volume
_links |
name |
string |
The name of the volume. This field cannot be specified in a PATCH method. |
uuid |
string |
flexcache_relationship
cluster |
create_time |
string |
Creation time of the relationship. |
ip_address |
string |
Cluster management IP of the remote cluster. |
size |
integer |
Size of the remote volume. |
state |
string |
Volume state |
svm |
volume |
prepopulate
FlexCache prepopulate
relative_size
FlexCache Relative Size
enabled |
boolean |
Specifies whether the relative sizing is enabled for the FlexCache volume. Relative sizing is introduced as a part of follow the origin feature. When relative sizing is enabled, it blocks any modifications done manually in the absolute size of the FlexCache volume. The size of the FlexCache volume is calculated and entered automatically based on the size of the origin volume. |
percentage |
integer |
Specifies the percent size the FlexCache volume should have relative to the total size of the origin volume. This property is only relevant to a FlexCache volume that has the relative size property enabled. |
s3
Flexcache S3
enabled |
boolean |
Indicates whether S3 access is enabled on the Flexcache volume. |
svm
FlexCache SVM
_links |
name |
string |
uuid |
string |
write
Flexcache Write settings
boolean |
Indicates whether Write Absorption is enabled on the FlexCache volume. Write Absorption enables the FlexCache volume to absorb writes locally and synchronize them with the origin volume. |
writeback
FlexCache Writeback
enabled |
boolean |
Indicates whether or not writeback is enabled for the FlexCache volume. Writeback is a storage method where data is first written to the FlexCache volume and then written to the origin of a FlexCache volume. |
flexcache
Defines the cache endpoint of FlexCache.
_links |
aggregates |
array[aggregates] |
atime_scrub |
FlexCache volume atime-based scrub |
cifs |
FlexCache CIFS |
cifs_change_notify |
Notifies that a change has been made to the FlexCache volume CIFS. |
integer |
Number of FlexCache constituents per aggregate when the 'aggregates' field is mentioned. |
dr_cache |
boolean |
If set to true, a DR cache is created. |
boolean |
Specifies whether or not a FlexCache volume has global file locking mode enabled. Global file locking mode is a mode where protocol read locking semantics are enforced across all FlexCaches and origins of a FlexCache volume. When global file locking mode is enabled, the "is_disconnected_mode_off_for_locks" flag is always set to "true". |
guarantee |
mtime_scrubber |
Flexcache Mtime Scrubber |
name |
string |
FlexCache name |
nfsv4 |
FlexCache NFSv4 |
origins |
array[flexcache_relationship] |
boolean |
If set to true, a plaintext FlexCache volume for an encrypted origin volume is created. |
path |
string |
The fully-qualified path in the owning SVM's namespace at which the FlexCache is mounted. The path is case insensitive and must be unique within a SVM's namespace. Path must begin with '/' and must not end with '/'. Only one FlexCache be mounted at any given junction path. |
relative_size |
FlexCache Relative Size |
s3 |
Flexcache S3 |
size |
integer |
Physical size of the FlexCache. The recommended size for a FlexCache is 10% of the origin volume. The minimum FlexCache constituent size is 1GB. |
svm |
FlexCache SVM |
boolean |
Specifies whether or not a Fabricpool-enabled aggregate can be used in FlexCache creation. The use_tiered_aggregate is only used when auto-provisioning a FlexCache volume. |
uuid |
string |
FlexCache UUID. Unique identifier for the FlexCache. |
write |
Flexcache Write settings |
writeback |
FlexCache Writeback |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
