Retrieve a FlexCache volume in the cluster
Retrieves a FlexCache volume in the cluster to access details about its configuration and state. This can help you manage and optimize storage resources by understanding the specifics of the FlexCache setup.
HTTP method and endpoint
GET /storage/flexcache/flexcaches
Introduced in
ONTAP 9.6
Usage notes
Retrieves FlexCache in the cluster.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
origins.ip_address- IP address of origin. -
origins.size- Physical size of origin. -
origins.state- State of origin. -
size- Physical size of FlexCache. -
guarantee.type- Space guarantee style of FlexCache. -
aggregates.nameoraggregates.uuid- Name or UUID of aggregate of FlexCache volume. -
path- Fully-qualified path of the owning SVM's namespace where the FlexCache is mounted.
Related ONTAP commands
volume flexcache show
Learn more
size |
integer |
query |
False |
Filter by size |
override_encryption |
boolean |
query |
False |
Filter by override_encryption
uuid |
string |
query |
False |
Filter by uuid |
global_file_locking_enabled |
boolean |
query |
False |
Filter by global_file_locking_enabled
origins.volume.uuid |
string |
query |
False |
Filter by origins.volume.uuid |
origins.volume.name |
string |
query |
False |
Filter by origins.volume.name |
origins.size |
integer |
query |
False |
Filter by origins.size |
origins.create_time |
string |
query |
False |
Filter by origins.create_time |
origins.state |
string |
query |
False |
Filter by origins.state |
origins.ip_address |
string |
query |
False |
Filter by origins.ip_address |
origins.cluster.name |
string |
query |
False |
Filter by origins.cluster.name |
origins.cluster.uuid |
string |
query |
False |
Filter by origins.cluster.uuid |
origins.svm.name |
string |
query |
False |
Filter by origins.svm.name |
origins.svm.uuid |
string |
query |
False |
Filter by origins.svm.uuid |
dr_cache |
boolean |
query |
False |
Filter by dr_cache
guarantee.type |
string |
query |
False |
Filter by guarantee.type
relative_size.enabled |
boolean |
query |
False |
Filter by relative_size.enabled
relative_size.percentage |
integer |
query |
False |
Filter by relative_size.percentage
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
name |
string |
query |
False |
Filter by name
path |
string |
query |
False |
Filter by path |
aggregates.uuid |
string |
query |
False |
Filter by aggregates.uuid |
aggregates.name |
string |
query |
False |
Filter by aggregates.name |
atime_scrub.period |
integer |
query |
False |
Filter by atime_scrub.period
atime_scrub.enabled |
boolean |
query |
False |
Filter by atime_scrub.enabled
constituents_per_aggregate |
integer |
query |
False |
Filter by constituents_per_aggregate |
writeback.enabled |
boolean |
query |
False |
Filter by writeback.enabled
cifs_change_notify.enabled |
boolean |
query |
False |
Filter by cifs_change_notify.enabled
use_tiered_aggregate |
boolean |
query |
False |
Filter by use_tiered_aggregate
return_timeout |
integer |
query |
False |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
order_by |
array[string] |
query |
False |
desc] direction. Default direction is 'asc' for ascending. |
return_records |
boolean |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[flexcache] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"aggregates": [
"name": "aggr1",
"guarantee": {
"type": "string"
"name": "vol1",
"origins": [
"cluster": {
"name": "cluster1",
"create_time": "2018-06-04 15:00:00 -0400",
"ip_address": "10.10.10.7",
"size": 0,
"state": "string",
"svm": {
"name": "svm1",
"volume": {
"name": "volume1",
"path": "/user/my_fc",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
aggregates
Aggregate
_links |
name |
string |
uuid |
string |
atime_scrub
FlexCache volume atime-based scrub
enabled |
boolean |
Specifies whether scrubbing of inactive files based on atime is enabled for the FlexCache volume. When scrubbing is enabled, files whose atime is older than the specified duration are evicted from the cache volume. The scrubber runs once a day and looks for files whose atime has exceeded the provisioned value. |
period |
integer |
Specifies the atime duration in days after which a cached file is considered inactive. Inactive files are purged from the FlexCache volumes when the scrubber runs once a day. |
cifs_change_notify
Notifies that a change has been made to the FlexCache volume CIFS.
enabled |
boolean |
Specifies whether a CIFS change notification is enabled for the FlexCache volume. |
guarantee
type |
string |
The type of space guarantee of this volume in the aggregate. |
cluster
_links |
name |
string |
uuid |
string |
svm
_links |
name |
string |
uuid |
string |
volume
_links |
name |
string |
The name of the volume. This field cannot be specified in a PATCH method. |
uuid |
string |
flexcache_relationship
cluster |
create_time |
string |
Creation time of the relationship. |
ip_address |
string |
Cluster management IP of the remote cluster. |
size |
integer |
Size of the remote volume. |
state |
string |
Volume state |
svm |
volume |
prepopulate
FlexCache prepopulate
relative_size
FlexCache Relative Size
enabled |
boolean |
Specifies whether the relative sizing is enabled for the FlexCache volume. Relative sizing is introduced as a part of follow the origin feature. When relative sizing is enabled, it blocks any modifications done manually in the absolute size of the FlexCache volume. The size of the FlexCache volume is calculated and entered automatically based on the size of the origin volume. |
percentage |
integer |
Specifies the percent size the FlexCache volume should have relative to the total size of the origin volume. This property is only relevant to a FlexCache volume that has the relative size property enabled. |
svm
FlexCache SVM
_links |
name |
string |
uuid |
string |
writeback
FlexCache Writeback
enabled |
boolean |
Indicates whether or not writeback is enabled for the FlexCache volume. Writeback is a storage method where data is first written to the FlexCache volume and then written to the origin of a FlexCache volume. |
flexcache
Defines the cache endpoint of FlexCache.
_links |
aggregates |
array[aggregates] |
atime_scrub |
FlexCache volume atime-based scrub |
cifs_change_notify |
Notifies that a change has been made to the FlexCache volume CIFS. |
integer |
Number of FlexCache constituents per aggregate when the 'aggregates' field is mentioned. |
dr_cache |
boolean |
If set to true, a DR cache is created. |
boolean |
Specifies whether or not a FlexCache volume has global file locking mode enabled. Global file locking mode is a mode where protocol read locking semantics are enforced across all FlexCaches and origins of a FlexCache volume. When global file locking mode is enabled, the "is_disconnected_mode_off_for_locks" flag is always set to "true". |
guarantee |
name |
string |
FlexCache name |
origins |
array[flexcache_relationship] |
boolean |
If set to true, a plaintext FlexCache volume for an encrypted origin volume is created. |
path |
string |
The fully-qualified path in the owning SVM's namespace at which the FlexCache is mounted. The path is case insensitive and must be unique within a SVM's namespace. Path must begin with '/' and must not end with '/'. Only one FlexCache be mounted at any given junction path. |
relative_size |
FlexCache Relative Size |
size |
integer |
Physical size of the FlexCache. The recommended size for a FlexCache is 10% of the origin volume. The minimum FlexCache constituent size is 1GB. |
svm |
FlexCache SVM |
boolean |
Specifies whether or not a Fabricpool-enabled aggregate can be used in FlexCache creation. The use_tiered_aggregate is only used when auto-provisioning a FlexCache volume. |
uuid |
string |
FlexCache UUID. Unique identifier for the FlexCache. |
writeback |
FlexCache Writeback |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
