Retrieve event catalog definitions
Accesses event catalog definitions to understand the various events that can occur within the system. This helps you manage and monitor system activities effectively.
HTTP method and endpoint
GET /support/ems/messages
Introduced in
ONTAP 9.6
Usage notes
Retrieves the event catalog definitions.
Related ONTAP commands
event catalog show
description |
string |
query |
False |
Filter by description |
deprecated |
boolean |
query |
False |
Filter by deprecated |
severity |
string |
query |
False |
Filter by severity |
name |
string |
query |
False |
Filter by name |
corrective_action |
string |
query |
False |
Filter by corrective_action |
snmp_trap_type |
string |
query |
False |
Filter by snmp_trap_type |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[records] |
"next": {
"href": "/api/resourcelink"
"num_records": 3,
"records": [
"corrective_action": "string",
"deprecated": 1,
"description": "string",
"name": "callhome.spares.low",
"severity": "error",
"snmp_trap_type": "standard"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
records
_links |
corrective_action |
string |
Corrective action |
deprecated |
boolean |
Is deprecated? |
description |
string |
Description |
name |
string |
Name of the event. |
severity |
string |
Severity |
snmp_trap_type |
string |
SNMP trap type |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
