Retrieve event catalog definitions
Retrieves event catalog definitions to understand and manage the types of events that can occur within your system. This is useful for monitoring and responding to specific events as they happen.
HTTP method and endpoint
GET /support/ems/messages
Introduced in
ONTAP 9.6
Related ONTAP commands
event catalog show
severity |
string |
query |
False |
Filter by severity |
corrective_action |
string |
query |
False |
Filter by corrective_action |
deprecated |
boolean |
query |
False |
Filter by deprecated |
name |
string |
query |
False |
Filter by name |
snmp_trap_type |
string |
query |
False |
Filter by snmp_trap_type |
description |
string |
query |
False |
Filter by description |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[records] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"corrective_action": "string",
"deprecated": 1,
"description": "string",
"name": "callhome.spares.low",
"severity": "error",
"snmp_trap_type": "standard"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
records
_links |
corrective_action |
string |
Corrective action |
deprecated |
boolean |
Is deprecated? |
description |
string |
Description of the event. |
name |
string |
Name of the event. |
severity |
string |
Severity |
snmp_trap_type |
string |
SNMP trap type |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
