REST API reference
Retrieve event catalog definitions
Retrieves event catalog definitions to access detailed information about events within the system, which can assist in monitoring and troubleshooting activities.
HTTP method and endpoint
GET /support/ems/messages
Introduced in
ONTAP 9.6
  • event catalog show
severity
string
query
False
Filter by severity
snmp_trap_type
string
query
False
Filter by snmp_trap_type
stateful
boolean
query
False
Filter by stateful
  • Introduced in: 9.11
name
string
query
False
Filter by name
description
string
query
False
Filter by description
deprecated
boolean
query
False
Filter by deprecated
corrective_action
string
query
False
Filter by corrective_action
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[records]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 3,
  "records": [
      "corrective_action": "string",
      "deprecated": 1,
      "description": "string",
      "name": "callhome.spares.low",
      "severity": "error",
      "snmp_trap_type": "standard"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
records
_links
_links
corrective_action
string
Corrective action
deprecated
boolean
Is deprecated?
description
string
Description of the event.
name
string
Name of the event.
severity
string
Severity
snmp_trap_type
string
SNMP trap type
stateful
boolean
Indicates whether the event is stateful. A stateful event tracks state changes of a system condition and reflects the current system condition while a stateless event simply reports a certain system condition that has occurred sometime in the past.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
