Retrieve event catalog definitions
Accesses the event catalog definitions to review the available event types and their attributes.
HTTP method and endpoint
GET /support/ems/messages
Introduced in
ONTAP 9.6
Usage notes
Retrieves the event catalog definitions.
Related ONTAP commands
event catalog show
description |
string |
query |
False |
Filter by description |
severity |
string |
query |
False |
Filter by severity |
name |
string |
query |
False |
Filter by name |
snmp_trap_type |
string |
query |
False |
Filter by snmp_trap_type |
deprecated |
boolean |
query |
False |
Filter by deprecated |
corrective_action |
string |
query |
False |
Filter by corrective_action |
filter.name |
string |
query |
False |
The filter name that applies to the query.
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[records] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"corrective_action": "string",
"deprecated": 1,
"description": "string",
"name": "callhome.spares.low",
"severity": "error",
"snmp_trap_type": "standard"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
983093 |
The provided filter is unknown. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
records
_links |
corrective_action |
string |
Corrective action |
deprecated |
boolean |
Is deprecated? |
description |
string |
Description of the event. |
name |
string |
Name of the event. |
severity |
string |
Severity |
snmp_trap_type |
string |
SNMP trap type |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
