Retrieve event catalog definitions
Retrieves event catalog definitions to access detailed information about events in your system. This helps you understand event types and their parameters for monitoring and analysis purposes.
HTTP method and endpoint
GET /support/ems/messages
Introduced in
ONTAP 9.6
Related ONTAP commands
event catalog show
deprecated |
boolean |
query |
False |
Filter by deprecated |
name |
string |
query |
False |
Filter by name |
snmp_trap_type |
string |
query |
False |
Filter by snmp_trap_type |
corrective_action |
string |
query |
False |
Filter by corrective_action |
severity |
string |
query |
False |
Filter by severity |
description |
string |
query |
False |
Filter by description |
filter.name |
string |
query |
False |
The filter name that applies to the query.
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[records] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"corrective_action": "string",
"deprecated": 1,
"description": "string",
"name": "callhome.spares.low",
"severity": "error",
"snmp_trap_type": "standard"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
983093 |
The provided filter is unknown. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
records
_links |
corrective_action |
string |
Corrective action |
deprecated |
boolean |
Is deprecated? |
description |
string |
Description of the event. |
name |
string |
Name of the event. |
severity |
string |
Severity |
snmp_trap_type |
string |
SNMP trap type |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
