Manage event filters
Manage event filters to configure and control specific filter instances within your ONTAP environment. These endpoints are used to retrieve, update, or delete filters based on your criteria, ensuring precise event management and notification handling.
Overview
Manages a specific filter instance. See the documentation for /support/ems/filters for details on the various properties.
Retrieving a specific filter instance
# The API:
GET /api/support/ems/filters/{name}
# The call:
curl -X GET "https://<mgmt-ip>/api/support/ems/filters/no-info-debug-events" -H "accept: application/hal+json"
# The response:
200 OK
# JSON Body
"name": "no-info-debug-events",
"rules": [
"index": 1,
"type": "include",
"message_criteria": {
"name_pattern": "*",
"severities": "emergency,alert,error,notice",
"snmp_trap_types": "*",
"related": {
"href": "/api/support/ems/messages?name=*&severity=emergency,alert,error,notice&snmp_trap_type=*"
"href": "/api/support/ems/filters/no-info-debug-events/rules/1"
"index": 2,
"type": "exclude",
"severities": "*",
"related": {
"href": "/api/support/ems/messages?name=*&severity=*&snmp_trap_type=*"
"href": "/api/support/ems/filters/no-info-debug-events/rules/2"
"href": "/api/support/ems/filters/no-info-debug-events"
Updating an existing filter with a new rule
# The API:
PATCH /api/support/ems/filters/{name}
# The call:
curl -X PATCH "https://<mgmt-ip>/api/support/ems/filters/test-filter" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "@test_ems_filters_patch.txt"
test_ems_filters_patch.txt(body):
"rules": [
"type": "include",
"name_pattern": "wafl.*",
"severities": "error"
# The response:
200 OK
Deleting an existing filter
# The API:
DELETE /api/support/ems/filters/{name}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/support/ems/filters/test-filter" -H "accept: application/hal+json"
# The response:
200 OK
