REST API reference
Manage event filters
Manage event filter instances by retrieving, updating, or deleting specific filters to control the logging and notification of system events. Use these endpoints to customize event handling based on criteria such as severity and message patterns.
Overview
Manages a specific filter instance. See the documentation for /support/ems/filters for details on the various properties.
Retrieving a specific filter instance
# The API:
GET /api/support/ems/filters/{name}
# The call:
curl -X GET "https://<mgmt-ip>/api/support/ems/filters/aggregate-events" -H "accept: application/hal+json"
# The response:
200 OK
# JSON Body
"name": "aggregate-events",
"rules": [
    "index": 1,
    "type": "include",
    "message_criteria": {
      "name_pattern": "*",
      "severities": "emergency,alert,error,notice",
      "snmp_trap_types": "*",
        "related": {
          "href": "/api/support/ems/messages?name=*&severity=emergency,alert,error,notice&snmp_trap_type=*"
    "parameter_criteria": [
        "name_pattern": "type",
        "value_pattern": "aggregate"
        "href": "/api/support/ems/filters/aggregate-events/rules/1"
    "index": 2,
    "type": "exclude",
      "severities": "*",
        "related": {
          "href": "/api/support/ems/messages?name=*&severity=*&snmp_trap_type=*"
        "value_pattern": "*"
        "href": "/api/support/ems/filters/aggregate-events/rules/2"
    "href": "/api/support/ems/filters/aggregate-events"
Updating an existing filter with a new rule
# The API:
PATCH /api/support/ems/filters/{name}
# The call:
curl -X PATCH "https://<mgmt-ip>/api/support/ems/filters/test-filter" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "@test_ems_filters_patch.txt"
test_ems_filters_patch.txt(body):
"rules": [
    "type": "include",
      "name_pattern": "wafl.*",
      "severities": "error"
# The response:
200 OK
Deleting an existing filter
# The API:
DELETE /api/support/ems/filters/{name}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/support/ems/filters/test-filter" -H "accept: application/hal+json"
# The response:
200 OK
