Manage event filters
Manage event filters to customize how system alerts are processed and delivered. Use these endpoints to retrieve, update, or delete specific filter instances based on your criteria.
Overview
Manages a specific filter instance. See the documentation for /support/ems/filters for details on the various properties.
Retrieving a specific filter instance
# The API:
GET /api/support/ems/filters/{name}
# The call:
curl -X GET "https://<mgmt-ip>/api/support/ems/filters/aggregate-events" -H "accept: application/hal+json"
# The response:
200 OK
# JSON Body
"name": "aggregate-events",
"rules": [
"index": 1,
"type": "include",
"message_criteria": {
"name_pattern": "*",
"severities": "emergency,alert,error,notice",
"snmp_trap_types": "*",
"related": {
"href": "/api/support/ems/messages?name=*&severity=emergency,alert,error,notice&snmp_trap_type=*"
"parameter_criteria": [
"name_pattern": "type",
"value_pattern": "aggregate"
"href": "/api/support/ems/filters/aggregate-events/rules/1"
"index": 2,
"type": "exclude",
"severities": "*",
"related": {
"href": "/api/support/ems/messages?name=*&severity=*&snmp_trap_type=*"
"value_pattern": "*"
"href": "/api/support/ems/filters/aggregate-events/rules/2"
"href": "/api/support/ems/filters/aggregate-events"
Updating an existing filter with a new rule
# The API:
PATCH /api/support/ems/filters/{name}
# The call:
curl -X PATCH "https://<mgmt-ip>/api/support/ems/filters/test-filter" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "@test_ems_filters_patch.txt"
test_ems_filters_patch.txt(body):
"rules": [
"type": "include",
"name_pattern": "wafl.*",
"severities": "error"
# The response:
200 OK
Deleting an existing filter
# The API:
DELETE /api/support/ems/filters/{name}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/support/ems/filters/test-filter" -H "accept: application/hal+json"
# The response:
200 OK
