Manage event filters
Use these endpoints to manage event filter instances, ensuring precise control over which system events are logged or monitored.
Overview
Manages a specific filter instance. See the documentation for /support/ems/filters for details on the various properties.
Retrieving a specific filter instance
# The API:
GET /api/support/ems/filters/{name}
# The call:
curl -X GET "https://<mgmt-ip>/api/support/ems/filters/aggregate-events" -H "accept: application/hal+json"
# The response:
200 OK
# JSON Body
"name": "aggregate-events",
"rules": [
"index": 1,
"type": "include",
"message_criteria": {
"name_pattern": "*",
"severities": "emergency,alert,error,notice",
"snmp_trap_types": "*",
"related": {
"href": "/api/support/ems/messages?name=*&severity=emergency,alert,error,notice&snmp_trap_type=*"
"parameter_criteria": [
"name_pattern": "type",
"value_pattern": "aggregate"
"href": "/api/support/ems/filters/aggregate-events/rules/1"
"index": 2,
"type": "exclude",
"severities": "*",
"related": {
"href": "/api/support/ems/messages?name=*&severity=*&snmp_trap_type=*"
"value_pattern": "*"
"href": "/api/support/ems/filters/aggregate-events/rules/2"
"href": "/api/support/ems/filters/aggregate-events"
Updating an existing filter with a new rule
# The API:
PATCH /api/support/ems/filters/{name}
# The call:
curl -X PATCH "https://<mgmt-ip>/api/support/ems/filters/test-filter" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "@test_ems_filters_patch.txt"
test_ems_filters_patch.txt(body):
"rules": [
"type": "include",
"name_pattern": "wafl.*",
"severities": "error"
# The response:
200 OK
Deleting an existing filter
# The API:
DELETE /api/support/ems/filters/{name}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/support/ems/filters/test-filter" -H "accept: application/hal+json"
# The response:
200 OK
