REST API reference
Manage event filters
Manage event filters to customize how EMS messages are processed within your ONTAP environment. These endpoints help configure specific filter instances to include or exclude events based on your criteria. Use them to tailor notifications and monitoring to suit your operational needs.
Overview
Manages a specific filter instance. See the documentation for /support/ems/filters for details on the various properties.
Retrieving a specific filter instance
# The API:
GET /api/support/ems/filters/{name}
# The call:
curl -X GET "https://<mgmt-ip>/api/support/ems/filters/aggregate-events" -H "accept: application/hal+json"
# The response:
200 OK
# JSON Body
"name": "aggregate-events",
"rules": [
    "index": 1,
    "type": "include",
    "message_criteria": {
      "name_pattern": "*",
      "severities": "emergency,alert,error,notice",
      "snmp_trap_types": "*",
        "related": {
          "href": "/api/support/ems/messages?name=*&severity=emergency,alert,error,notice&snmp_trap_type=*"
    "parameter_criteria": [
        "name_pattern": "type",
        "value_pattern": "aggregate"
        "href": "/api/support/ems/filters/aggregate-events/rules/1"
    "index": 2,
    "type": "exclude",
      "severities": "*",
        "related": {
          "href": "/api/support/ems/messages?name=*&severity=*&snmp_trap_type=*"
        "value_pattern": "*"
        "href": "/api/support/ems/filters/aggregate-events/rules/2"
    "href": "/api/support/ems/filters/aggregate-events"
Updating an existing filter with a new rule
# The API:
PATCH /api/support/ems/filters/{name}
# The call:
curl -X PATCH "https://<mgmt-ip>/api/support/ems/filters/test-filter" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "@test_ems_filters_patch.txt"
test_ems_filters_patch.txt(body):
"rules": [
    "type": "include",
      "name_pattern": "wafl.*",
      "severities": "error"
# The response:
200 OK
Deleting an existing filter
# The API:
DELETE /api/support/ems/filters/{name}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/support/ems/filters/test-filter" -H "accept: application/hal+json"
# The response:
200 OK
