Prepopulates a flexcache volume in the cluster
prepopulatedir_paths- list of directory-paths to be prepopulated for the flexcache volume # recommended optional properties -
prepopulateexclude_dir_paths- list of directory-paths to be excluded from prepopulation for the flexcache volume # default property values if not specified in patch, the following default property value is assigned: -
prepopulaterecurse- default value is "true" # related ontap commands -
volume flexcache prepopulate start# learn more -
doc /storage/flexcache/flexcaches](#docs-storage-storage_flexcache_flexcaches)
PATCH /storage/flexcache/flexcaches/{uuid}
Introduced In: 9.8
Prepopulates a FlexCache volume in the cluster.
Required properties
uuid- FlexCache volume UUID. -
prepopulate.dir_paths- List of directory-paths to be prepopulated for the FlexCache volume.
Recommended optional properties
prepopulate.exclude_dir_paths- List of directory-paths to be excluded from prepopulation for the FlexCache volume.
Default property values
If not specified in PATCH, the following default property value is assigned:
prepopulate.recurse- Default value is "true".
Related ONTAP commands
Learn more
uuid |
string |
path |
True |
Unique identifier of the FlexCache volume. |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
prepopulate |
FlexCache prepopulate |
uuid |
string |
FlexCache UUID. Unique identifier for the FlexCache. |
Example request
"dr_cache": null,
"global_file_locking_enabled": null,
"prepopulate": {
"dir_paths": [
"/dir1"
"exclude_dir_paths": [
"/dir1/dir2"
"use_tiered_aggregate": null,
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
66846922 |
FlexCache volume does not exist in the SVM |
66846923 |
Failed to prepopulate FlexCache volume because the origin volume is not reachable |
66846924 |
FlexCache volume is offline |
66846925 |
FlexCache volume is not mounted or the junction-path is not active |
66846926 |
The junction-path of FlexCache volume is not active |
66846927 |
FlexCache volume does not have an origin volume |
66846928 |
FlexCache volume does not exist |
66846929 |
Using FlexCache prepopulate requires an effective cluster version of 9.8.0 or later |
66846930 |
Using FlexCache prepopulate in a MetroCluster configuration requires an effective cluster version of 9.8.0 or later on both the local and remote clusters |
66846931 |
Internal Error. FlexCache prepopulate job queue failed. Wait a few minutes, and then try the operation again |
66846936 |
Failed to lookup root file handle for origin of FlexCache volume. Wait a few minutes, and then try the operation again |
66846937 |
Internal error. Failed to initialize thread |
66846939 |
Internal error. Failed to get the MSID of the origin volume for FlexCache volume |
66846943 |
Failed to prepopulate because dir_path does not exist |
66846944 |
Failed to get root constituent for FlexCache volume |
66846945 |
Origin of FlexCache volume is not mounted or the junction-path is not active |
66846946 |
The junction-path of origin of FlexCache volume is not active |
66846947 |
FlexCache prepopulate job for FlexCache volume already exists |
66846948 |
FlexCache prepopulate job for FlexCache volume could not be queued because the node is offline |
href |
string |
_links
aggregates
Aggregate
name |
string |
uuid |
string |
guarantee
type |
string |
The type of space guarantee of this volume in the aggregate. |
cluster
name |
string |
uuid |
string |
svm
name |
string |
The name of the SVM. |
uuid |
string |
volume
name |
string |
The name of the volume. |
uuid |
string |
flexcache_relationship
cluster |
create_time |
string |
Creation time of the relationship. |
ip_address |
string |
Cluster managerment IP of the remote cluster. |
size |
integer |
Size of the remote volume. |
state |
string |
Volume state |
volume |
prepopulate
dir_paths |
array[string] |
exclude_dir_paths |
array[string] |
recurse |
boolean |
Specifies whether or not the prepopulate action should search through the |
svm
FlexCache SVM
name |
string |
uuid |
string |
flexcache
Defines the cache endpoint of FlexCache.
prepopulate |
uuid |
string |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
