Pre-populate a FlexCache volume in the cluster
PATCH /storage/flexcache/flexcaches/{uuid}
Introduced In: 9.8
Prepopulates a FlexCache volume in the cluster.
Required properties
uuid- FlexCache volume UUID. -
prepopulate.dir_paths- List of directory-paths to be prepopulated for the FlexCache volume.
Recommended optional properties
prepopulate.exclude_dir_paths- List of directory-paths to be excluded from prepopulation for the FlexCache volume. -
prepopulate.dir_paths- List of directory-paths to be prepopulated for the FlexCache volume. -
writeback.enabled- false. This property specifies whether writeback is enabled for the FlexCache volume.
#* writeback.per_inode_dirty_limit - This property specifies the amount of data in 4KB blocks that the system can write per inode in a FlexCache volume before a writeback is initiated for that inode.
#* writeback.transfer_limit - This property specifies the maximum number of 4KB data blocks the system can transfer, at one time, from the cache to the origin. This process will keep on recurring until all the dirty blocks for the inode are transferred to the origin volume.
#* writeback.scrub_threshold - This property specifies the threshold value in 4KB data blocks which when hit will trigger a scrub that will initiate writeback for all dirty inodes on the FlexCache volume.
relative_size.enabled- This property specifies whether the relative sizing is enabled for the FlexCache volume. -
relative_size.percentage- This property specifies the percent size FlexCache volume should have relative to the total size of the origin volume.
Default property values
If not specified in PATCH, the following default property value is assigned:
prepopulate.recurse- Default value is "true".
Related ONTAP commands
volume flexcache prepopulate start
Learn more
uuid |
string |
path |
True |
Unique identifier of the FlexCache volume. |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
prepopulate |
FlexCache prepopulate |
uuid |
string |
FlexCache UUID. Unique identifier for the FlexCache. |
writeback |
FlexCache Writeback |
Example request
"dr_cache": true,
"global_file_locking_enabled": true,
"prepopulate": {
"dir_paths": [
"/dir1"
"exclude_dir_paths": [
"/dir1/dir2"
"use_tiered_aggregate": true,
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
66846922 |
FlexCache volume does not exist in the SVM |
66846923 |
Failed to prepopulate FlexCache volume because the origin volume is not reachable |
66846924 |
FlexCache volume is offline |
66846925 |
FlexCache volume is not mounted or the junction-path is not active |
66846926 |
The junction-path of FlexCache volume is not active |
66846927 |
FlexCache volume does not have an origin volume |
66846928 |
FlexCache volume does not exist |
66846929 |
Using FlexCache prepopulate requires an effective cluster version of 9.8.0 or later |
66846930 |
Using FlexCache prepopulate in a MetroCluster configuration requires an effective cluster version of 9.8.0 or later on both the local and remote clusters |
66846931 |
Internal Error. FlexCache prepopulate job queue failed. Wait a few minutes, and then try the operation again |
66846936 |
Failed to lookup root file handle for origin of FlexCache volume. Wait a few minutes, and then try the operation again |
66846937 |
Internal error. Failed to initialize thread |
66846939 |
Internal error. Failed to get the MSID of the origin volume for FlexCache volume |
66846943 |
Failed to prepopulate because dir_path does not exist |
66846944 |
Failed to get root constituent for FlexCache volume |
66846945 |
Origin of FlexCache volume is not mounted or the junction-path is not active |
66846946 |
The junction-path of origin of FlexCache volume is not active |
66846947 |
FlexCache prepopulate job for FlexCache volume already exists |
66846948 |
FlexCache prepopulate job for FlexCache volume could not be queued because the node is offline |
href |
string |
_links
aggregates
name |
string |
uuid |
string |
guarantee
type |
string |
The type of space guarantee of this volume in the aggregate. |
cluster
name |
string |
uuid |
string |
svm
name |
string |
The name of the SVM. |
uuid |
string |
volume
name |
string |
The name of the volume. |
uuid |
string |
flexcache_relationship
cluster |
create_time |
string |
Creation time of the relationship. |
ip_address |
string |
Cluster managerment IP of the remote cluster. |
size |
integer |
Size of the remote volume. |
state |
string |
Volume state |
volume |
prepopulate
dir_paths |
array[string] |
exclude_dir_paths |
array[string] |
recurse |
boolean |
Specifies whether or not the prepopulate action should search through the |
svm
FlexCache SVM
name |
string |
uuid |
string |
writeback
FlexCache Writeback
enabled |
boolean |
Indicates whether or not writeback is enabled for the FlexCache volume. Writeback is a storage method where data is first written to the FlexCache volume and then written to the origin of a FlexCache volume. |
flexcache
Defines the cache endpoint of FlexCache.
prepopulate |
uuid |
string |
writeback |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
