REST API reference
Pre-populate a FlexCache volume in the cluster
PATCH /storage/flexcache/flexcaches/{uuid}
Introduced In: 9.8
Prepopulates a FlexCache volume in the cluster, or modifies configuration of the FlexCache volume.
  • uuid - FlexCache volume UUID.
  • prepopulate.exclude_dir_paths - List of directory-paths to be excluded from prepopulation for the FlexCache volume.
  • prepopulate.dir_paths - List of directory-paths to be prepopulated for the FlexCache volume.
  • writeback.enabled - false. This property specifies whether writeback is enabled for the FlexCache volume.
  • relative_size.enabled - This property specifies whether the relative sizing is enabled for the FlexCache volume.
  • relative_size.percentage - This property specifies the percent size FlexCache volume should have relative to the total size of the origin volume.
  • atime_scrub.enabled - This property specifies whether the atime based scrub is enabled for the FlexCache volume.
  • atime_scrub.period - This property specifies the duration in days after which inactive files can be scrubbed from FlexCache volume.
  • cifs_change_notify.enabled - This property specifies whether a CIFS change notification is enabled for the FlexCache volume.
Default property values
If not specified in PATCH, the following default property value is assigned:
  • prepopulate.recurse - Default value is "true".
  • volume flexcache prepopulate start
  • volume flexcache config modify
uuid
string
path
True
Unique identifier of the FlexCache volume.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
atime_scrub
atime_scrub
FlexCache volume atime-based scrub
cifs_change_notify
cifs_change_notify
Notifies that a change has been made to the FlexCache volume CIFS.
prepopulate
prepopulate
FlexCache prepopulate
relative_size
relative_size
FlexCache Relative Size
uuid
string
FlexCache UUID. Unique identifier for the FlexCache.
writeback
writeback
FlexCache Writeback
Example request
  "dr_cache": true,
  "global_file_locking_enabled": true,
  "override_encryption": true,
  "prepopulate": {
    "dir_paths": [
      "/dir1"
    "exclude_dir_paths": [
      "/dir1/dir2"
  "use_tiered_aggregate": true,
Status: 200, Ok
job
job_link
  "job": {
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
66846921
Failed to prepopulate. Empty path list
66846922
FlexCache volume does not exist in the SVM
66846923
Failed to prepopulate FlexCache volume because the origin volume is not reachable
66846924
FlexCache volume is offline
66846925
FlexCache volume is not mounted or the junction-path is not active
66846926
The junction-path of FlexCache volume is not active
66846927
FlexCache volume does not have an origin volume
66846928
66846929
Using FlexCache prepopulate requires an effective cluster version of 9.8.0 or later
66846930
Using FlexCache prepopulate in a MetroCluster configuration requires an effective cluster version of 9.8.0 or later on both the local and remote clusters
66846931
Internal Error. FlexCache prepopulate job queue failed. Wait a few minutes, and then try the operation again
66846936
Failed to lookup root file handle for origin of FlexCache volume. Wait a few minutes, and then try the operation again
66846937
Internal error. Failed to initialize thread
66846939
Internal error. Failed to get the MSID of the origin volume for FlexCache volume
66846943
Failed to prepopulate because dir_path does not exist
66846944
Failed to get root constituent for FlexCache volume
66846945
Origin of FlexCache volume is not mounted or the junction-path is not active
66846946
The junction-path of origin of FlexCache volume is not active
66846947
FlexCache prepopulate job for FlexCache volume already exists
66846948
FlexCache prepopulate job for FlexCache volume could not be queued because the node is offline
66846958
Exclude path(s) does not exist in origin volume
66846988
Cannot enable writeback for FlexCache volume because the origin is a data protection volume. Writeback is only supported on FlexCache volumes with origins that are read-write volumes
66846995
Using FlexCache relative-size requires an effective cluster version of 9.13.1 or later
66846997
Failed to modify the relative-size-percentage property of the FlexCache volume because the used size of the FlexCache Volume is greater than the newly calculated size based on the value of the relative-size-percentage property
66846997
Failed to modify the relative-size-percentage property of FlexCache volume because the relative-size-percentage property is not valid
66846998
Failed to modify the relative-size-percentage property of FlexCache volume because the is-relative-size-enabled property is false
66847010
Failed to modify the relative-size-percentage property of FlexCache volume because autosize is enabled on the FlexCache volume
66847026
Failed to enable the atime-scrub-enabled property for the FlexCache volume because the atime-update-property is false
66847027
Failed to modify atime-scrub-period property of the FlexCache volume because the atime-scrub-enabled property is false
string
aggregates
Aggregate
name
string
uuid
string
atime_scrub
enabled
boolean
Specifies whether scrubbing of inactive files based on atime is enabled for the FlexCache volume. When scrubbing is enabled, files whose atime is older than the specified duration are evicted from the cache volume. The scrubber runs once a day and looks for files whose atime has exceeded the provisioned value.
period
integer
Specifies the atime duration in days after which a cached file is considered inactive. Inactive files are purged from the FlexCache volumes when the scrubber runs once a day.
cifs_change_notify
enabled
boolean
Specifies whether a CIFS change notification is enabled for the FlexCache volume.
guarantee
type
string
The type of space guarantee of this volume in the aggregate.
cluster
name
string
uuid
string
svm
name
string
uuid
string
volume
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
flexcache_relationship
cluster
cluster
create_time
string
Creation time of the relationship.
ip_address
string
Cluster management IP of the remote cluster.
size
integer
Size of the remote volume.
state
string
Volume state
volume
volume
prepopulate
dir_paths
array[string]
exclude_dir_paths
array[string]
recurse
boolean
Specifies whether or not the prepopulate action should search through the dir_paths recursively. If not set, the default value true is used.
relative_size
enabled
boolean
Specifies whether the relative sizing is enabled for the FlexCache volume. Relative sizing is introduced as a part of follow the origin feature. When relative sizing is enabled, it blocks any modifications done manually in the absolute size of the FlexCache volume. The size of the FlexCache volume is calculated and entered automatically based on the size of the origin volume.
percentage
integer
Specifies the percent size the FlexCache volume should have relative to the total size of the origin volume. This property is only relevant to a FlexCache volume that has the relative size property enabled.
svm
FlexCache SVM
name
string
uuid
string
writeback
FlexCache Writeback
enabled
boolean
Indicates whether or not writeback is enabled for the FlexCache volume. Writeback is a storage method where data is first written to the FlexCache volume and then written to the origin of a FlexCache volume.
flexcache
Defines the cache endpoint of FlexCache.
atime_scrub
atime_scrub
cifs_change_notify
cifs_change_notify
prepopulate
prepopulate
relative_size
relative_size
uuid
string
writeback
writeback
FlexCache Writeback
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
