Pre-populate a FlexCache volume in the cluster
Prepopulates a FlexCache volume in the cluster to optimize data access by ensuring specific data is readily available. Use this endpoint when you need to adjust the configuration or selectively prepopulate data paths for efficient cache management.
HTTP method and endpoint
PATCH /storage/flexcache/flexcaches/{uuid}
Introduced in
ONTAP 9.8
Usage notes
Prepopulates a FlexCache volume in the cluster, or modifies configuration of the FlexCache volume.
Required properties
uuid- FlexCache volume UUID.
Recommended optional properties
prepopulate.exclude_dir_paths- List of directory-paths to be excluded from prepopulation for the FlexCache volume. -
prepopulate.dir_paths- List of directory-paths to be prepopulated for the FlexCache volume. -
writeback.enabled- false. This property specifies whether writeback is enabled for the FlexCache volume. -
relative_size.enabled- This property specifies whether the relative sizing is enabled for the FlexCache volume. -
relative_size.percentage- This property specifies the percent size FlexCache volume should have relative to the total size of the origin volume. -
atime_scrub.enabled- This property specifies whether the atime based scrub is enabled for the FlexCache volume. -
atime_scrub.period- This property specifies the duration in days after which inactive files can be scrubbed from FlexCache volume. -
cifs_change_notify.enabled- This property specifies whether a CIFS change notification is enabled for the FlexCache volume.
Default property values
If not specified in PATCH, the following default property value is assigned:
prepopulate.recurse- Default value is "true".
Related ONTAP commands
volume flexcache prepopulate start -
volume flexcache config modify
Learn more
uuid |
string |
path |
True |
Unique identifier of the FlexCache volume. |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
atime_scrub |
FlexCache volume atime-based scrub |
cifs_change_notify |
Notifies that a change has been made to the FlexCache volume CIFS. |
prepopulate |
FlexCache prepopulate |
relative_size |
FlexCache Relative Size |
uuid |
string |
FlexCache UUID. Unique identifier for the FlexCache. |
writeback |
FlexCache Writeback |
Example request
"dr_cache": true,
"global_file_locking_enabled": true,
"override_encryption": true,
"prepopulate": {
"dir_paths": [
"/dir1"
"exclude_dir_paths": [
"/dir1/dir2"
"use_tiered_aggregate": true,
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
66846921 |
Failed to prepopulate. Empty path list |
66846922 |
FlexCache volume does not exist in the SVM |
66846923 |
Failed to prepopulate FlexCache volume because the origin volume is not reachable |
66846924 |
FlexCache volume is offline |
66846925 |
FlexCache volume is not mounted or the junction-path is not active |
66846926 |
The junction-path of FlexCache volume is not active |
66846927 |
FlexCache volume does not have an origin volume |
66846928 |
FlexCache volume does not exist |
66846929 |
Using FlexCache prepopulate requires an effective cluster version of 9.8.0 or later |
66846930 |
Using FlexCache prepopulate in a MetroCluster configuration requires an effective cluster version of 9.8.0 or later on both the local and remote clusters |
66846931 |
Internal Error. FlexCache prepopulate job queue failed. Wait a few minutes, and then try the operation again |
66846936 |
Failed to lookup root file handle for origin of FlexCache volume. Wait a few minutes, and then try the operation again |
66846937 |
Internal error. Failed to initialize thread |
66846939 |
Internal error. Failed to get the MSID of the origin volume for FlexCache volume |
66846943 |
Failed to prepopulate because dir_path does not exist |
66846944 |
Failed to get root constituent for FlexCache volume |
66846945 |
Origin of FlexCache volume is not mounted or the junction-path is not active |
66846946 |
The junction-path of origin of FlexCache volume is not active |
66846947 |
FlexCache prepopulate job for FlexCache volume already exists |
66846948 |
FlexCache prepopulate job for FlexCache volume could not be queued because the node is offline |
66846958 |
Exclude path(s) does not exist in origin volume |
66846988 |
Cannot enable writeback for FlexCache volume because the origin is a data protection volume. Writeback is only supported on FlexCache volumes with origins that are read-write volumes |
66846995 |
Using FlexCache relative-size requires an effective cluster version of 9.13.1 or later |
66846997 |
Failed to modify the relative-size-percentage property of the FlexCache volume because the used size of the FlexCache Volume is greater than the newly calculated size based on the value of the relative-size-percentage property |
66846997 |
Failed to modify the relative-size-percentage property of FlexCache volume because the relative-size-percentage property is not valid |
66846998 |
Failed to modify the relative-size-percentage property of FlexCache volume because the is-relative-size-enabled property is false |
66847010 |
Failed to modify the relative-size-percentage property of FlexCache volume because autosize is enabled on the FlexCache volume |
66847026 |
Failed to enable the atime-scrub-enabled property for the FlexCache volume because the atime-update-property is false |
66847027 |
Failed to modify atime-scrub-period property of the FlexCache volume because the atime-scrub-enabled property is false |
href |
string |
_links
aggregates
Aggregate
name |
string |
uuid |
string |
atime_scrub
enabled |
boolean |
Specifies whether scrubbing of inactive files based on atime is enabled for the FlexCache volume. When scrubbing is enabled, files whose atime is older than the specified duration are evicted from the cache volume. The scrubber runs once a day and looks for files whose atime has exceeded the provisioned value. |
period |
integer |
Specifies the atime duration in days after which a cached file is considered inactive. Inactive files are purged from the FlexCache volumes when the scrubber runs once a day. |
cifs_change_notify
enabled |
boolean |
Specifies whether a CIFS change notification is enabled for the FlexCache volume. |
guarantee
type |
string |
The type of space guarantee of this volume in the aggregate. |
cluster
name |
string |
uuid |
string |
svm
name |
string |
uuid |
string |
volume
name |
string |
The name of the volume. This field cannot be specified in a PATCH method. |
uuid |
string |
flexcache_relationship
cluster |
create_time |
string |
Creation time of the relationship. |
ip_address |
string |
Cluster management IP of the remote cluster. |
size |
integer |
Size of the remote volume. |
state |
string |
Volume state |
volume |
prepopulate
dir_paths |
array[string] |
exclude_dir_paths |
array[string] |
recurse |
boolean |
Specifies whether or not the prepopulate action should search through the |
relative_size
enabled |
boolean |
Specifies whether the relative sizing is enabled for the FlexCache volume. Relative sizing is introduced as a part of follow the origin feature. When relative sizing is enabled, it blocks any modifications done manually in the absolute size of the FlexCache volume. The size of the FlexCache volume is calculated and entered automatically based on the size of the origin volume. |
percentage |
integer |
Specifies the percent size the FlexCache volume should have relative to the total size of the origin volume. This property is only relevant to a FlexCache volume that has the relative size property enabled. |
svm
FlexCache SVM
name |
string |
uuid |
string |
writeback
FlexCache Writeback
enabled |
boolean |
Indicates whether or not writeback is enabled for the FlexCache volume. Writeback is a storage method where data is first written to the FlexCache volume and then written to the origin of a FlexCache volume. |
flexcache
Defines the cache endpoint of FlexCache.
atime_scrub |
prepopulate |
relative_size |
uuid |
string |
writeback |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
