REST API reference
Prepopulates a flexcache volume in the cluster, or modifies configuration of the flexcache volume
  • prepopulateexclude_dir_paths - list of directory-paths to be excluded from prepopulation for the flexcache volume
  • prepopulatedir_paths - list of directory-paths to be prepopulated for the flexcache volume
  • writebackenabled - false this property specifies whether writeback is enabled for the flexcache volume
  • relative_sizeenabled - this property specifies whether the relative sizing is enabled for the flexcache volume
  • relative_sizepercentage - this property specifies the percent size flexcache volume should have relative to the total size of the origin volume # default property values if not specified in patch, the following default property value is assigned:
  • prepopulaterecurse - default value is "true" # related ontap commands
  • volume flexcache prepopulate start
  • volume flexcache config modify # learn more
  • [doc /storage/flexcache/flexcaches](#docs-storage-storage_flexcache_flexcaches)
PATCH /storage/flexcache/flexcaches/{uuid}
Introduced In: 9.8
Prepopulates a FlexCache volume in the cluster, or modifies configuration of the FlexCache volume.
Required properties
  • uuid - FlexCache volume UUID.
  • prepopulate.exclude_dir_paths - List of directory-paths to be excluded from prepopulation for the FlexCache volume.
  • prepopulate.dir_paths - List of directory-paths to be prepopulated for the FlexCache volume.
  • writeback.enabled - false. This property specifies whether writeback is enabled for the FlexCache volume.
  • relative_size.enabled - This property specifies whether the relative sizing is enabled for the FlexCache volume.
  • relative_size.percentage - This property specifies the percent size FlexCache volume should have relative to the total size of the origin volume.
Default property values
If not specified in PATCH, the following default property value is assigned:
  • prepopulate.recurse - Default value is "true".
uuid
string
path
True
Unique identifier of the FlexCache volume.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
prepopulate
prepopulate
FlexCache prepopulate
relative_size
relative_size
FlexCache Relative Size
uuid
string
FlexCache UUID. Unique identifier for the FlexCache.
writeback
writeback
FlexCache Writeback
Example request
  "dr_cache": true,
  "global_file_locking_enabled": true,
  "prepopulate": {
    "dir_paths": [
      "/dir1"
    "exclude_dir_paths": [
      "/dir1/dir2"
  "use_tiered_aggregate": true,
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
66846922
FlexCache volume does not exist in the SVM
66846923
Failed to prepopulate FlexCache volume because the origin volume is not reachable
66846924
FlexCache volume is offline
66846925
FlexCache volume is not mounted or the junction-path is not active
66846926
The junction-path of FlexCache volume is not active
66846927
FlexCache volume does not have an origin volume
66846928
66846929
Using FlexCache prepopulate requires an effective cluster version of 9.8.0 or later
66846930
Using FlexCache prepopulate in a MetroCluster configuration requires an effective cluster version of 9.8.0 or later on both the local and remote clusters
66846931
Internal Error. FlexCache prepopulate job queue failed. Wait a few minutes, and then try the operation again
66846936
Failed to lookup root file handle for origin of FlexCache volume. Wait a few minutes, and then try the operation again
66846937
Internal error. Failed to initialize thread
66846939
Internal error. Failed to get the MSID of the origin volume for FlexCache volume
66846943
Failed to prepopulate because dir_path does not exist
66846944
Failed to get root constituent for FlexCache volume
66846945
Origin of FlexCache volume is not mounted or the junction-path is not active
66846946
The junction-path of origin of FlexCache volume is not active
66846947
FlexCache prepopulate job for FlexCache volume already exists
66846948
FlexCache prepopulate job for FlexCache volume could not be queued because the node is offline
string
aggregates
name
string
uuid
string
guarantee
type
string
The type of space guarantee of this volume in the aggregate.
cluster
name
string
uuid
string
svm
name
string
The name of the SVM.
uuid
string
volume
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
flexcache_relationship
cluster
cluster
create_time
string
Creation time of the relationship.
ip_address
string
Cluster managerment IP of the remote cluster.
size
integer
Size of the remote volume.
state
string
Volume state
volume
volume
prepopulate
dir_paths
array[string]
exclude_dir_paths
array[string]
recurse
boolean
Specifies whether or not the prepopulate action should search through the dir_paths recursively. If not set, the default value true is used.
relative_size
enabled
boolean
Specifies whether the relative sizing is enabled for the FlexCache volume. Relative sizing is introduced as a part of follow the origin feature. When relative sizing is enabled, it blocks any modifications done manually in the absolute size of the FlexCache volume. The size of the FlexCache volume is calculated and entered automatically based on the size of the origin volume.
percentage
integer
Specifies the percent size the FlexCache volume should have relative to the total size of the origin volume. This property is only relevant to a FlexCache volume that has the relative size property enabled.
svm
FlexCache SVM
name
string
uuid
string
writeback
FlexCache Writeback
enabled
boolean
Indicates whether or not writeback is enabled for the FlexCache volume. Writeback is a storage method where data is first written to the FlexCache volume and then written to the origin of a FlexCache volume.
flexcache
Defines the cache endpoint of FlexCache.
prepopulate
prepopulate
relative_size
relative_size
uuid
string
writeback
writeback
FlexCache Writeback
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
