REST API reference
Update cluster-wide SNMP configuration
Updates the SNMP configuration for the entire cluster to manage settings like SNMP and authentication traps. This can also trigger an SNMP test trap when needed.
HTTP method and endpoint
PATCH /support/snmp
Introduced in
ONTAP 9.7
Usage notes
Updates the cluster wide SNMP configuration, such as, enabling or disabling SNMP, enabling or disabling SNMP traps, and enabling or disabling authentication traps. It can also be used to trigger an SNMP test trap.
  • options snmp.enable
  • system snmp authtrap
  • system snmp init
Learn more
Request Body
Name Type Description
auth_traps_enabled
boolean
Specifies whether to enable or disable SNMP authentication traps.
enabled
boolean
Specifies whether to enable or disable SNMP.
traps_enabled
boolean
Specifies whether to enable or disable SNMP traps.
trigger_test_trap
boolean
Trigger a test SNMP trap.
Example request
  "auth_traps_enabled": 1,
  "enabled": 1,
  "traps_enabled": 1,
  "trigger_test_trap": 1
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1179738
Cluster identification not available for modification since a cluster has not been created.
1179739
Cluster identification modification is not available in maintenance mode or other boot modes.
string
snmp
Cluster-wide SNMP configuration.
auth_traps_enabled
boolean
enabled
boolean
traps_enabled
boolean
trigger_test_trap
boolean
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
