Update the cluster-wide SNMP configuration
Updates the SNMP configuration for the entire cluster, including enabling or disabling SNMP and its traps. Use this to configure authentication traps or initiate an SNMP test trap.
HTTP method and endpoint
PATCH /support/snmp
Introduced in
ONTAP 9.7
Usage notes
Updates the cluster wide SNMP configuration, such as, enabling or disabling SNMP, enabling or disabling SNMP traps, and enabling or disabling authentication traps. It can also be used to trigger an SNMP test trap.
Related ONTAP commands
options snmp.enable -
system snmp authtrap -
system snmp init
Learn more
Request Body
| Name | Type | Description |
auth_traps_enabled |
boolean |
Specifies whether to enable or disable SNMP authentication traps. |
enabled |
boolean |
Specifies whether to enable or disable SNMP. |
traps_enabled |
boolean |
Specifies whether to enable or disable SNMP traps. |
trigger_test_trap |
boolean |
Trigger a test SNMP trap. |
Example request
"auth_traps_enabled": 1,
"enabled": 1,
"traps_enabled": 1,
"trigger_test_trap": 1
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1179738 |
Cluster identification not available for modification since a cluster has not been created. |
1179739 |
Cluster identification modification is not available in maintenance mode or other boot modes. |
href |
string |
self_link
snmp
Cluster-wide SNMP configuration.
boolean |
enabled |
boolean |
traps_enabled |
boolean |
trigger_test_trap |
boolean |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
