Update the cluster-wide SNMP configuration
Updates the cluster-wide SNMP configuration to manage SNMP settings, including enabling or disabling features like SNMP traps and authentication traps. You can also use this endpoint to trigger an SNMP test trap.
HTTP method and endpoint
PATCH /support/snmp
Introduced in
ONTAP 9.7
Usage notes
Updates the cluster wide SNMP configuration, such as, enabling or disabling SNMP, enabling or disabling SNMP traps, and enabling or disabling authentication traps. It can also be used to trigger an SNMP test trap.
Related ONTAP commands
options snmp.enable -
system snmp authtrap -
system snmp init
Learn more
Request Body
| Name | Type | Description |
auth_traps_enabled |
boolean |
Specifies whether to enable or disable SNMP authentication traps. |
enabled |
boolean |
Specifies whether to enable or disable SNMP. |
traps_enabled |
boolean |
Specifies whether to enable or disable SNMP traps. |
trigger_test_trap |
boolean |
Trigger a test SNMP trap. |
Example request
"auth_traps_enabled": 1,
"enabled": 1,
"traps_enabled": 1,
"trigger_test_trap": 1
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1179738 |
Cluster identification not available for modification since a cluster has not been created. |
1179739 |
Cluster identification modification is not available in maintenance mode or other boot modes. |
href |
string |
self_link
snmp
Cluster-wide SNMP configuration.
boolean |
enabled |
boolean |
traps_enabled |
boolean |
trigger_test_trap |
boolean |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
