REST API reference
Update the cluster-wide SNMP configuration
Updates the cluster-wide SNMP configuration to manage settings such as enabling SNMP, configuring SNMP traps, and setting server contact information. Use this endpoint to ensure SNMP settings align with your network management requirements.
HTTP method and endpoint
PATCH /support/snmp
Introduced in
ONTAP 9.7
Usage notes
Updates the cluster wide SNMP configuration, such as:
  • enabling or disabling SNMP
  • enabling or disabling SNMP traps
  • enabling or disabling authentication traps
  • setting the contact and location information for the SNMP server
  • triggering an SNMP test trap
  • options snmp.enable
  • system snmp authtrap
  • system snmp init
Learn more
Request Body
Name Type Description
auth_traps_enabled
boolean
Specifies whether to enable or disable SNMP authentication traps.
contact
string
Specifies the contact person for the SNMP server
enabled
boolean
Specifies whether to enable or disable SNMP.
location
string
Specifies the location of the SNMP server
traps_enabled
boolean
Specifies whether to enable or disable SNMP traps.
trigger_test_trap
boolean
Trigger a test SNMP trap.
Example request
  "auth_traps_enabled": 1,
  "contact": "support@company.com",
  "enabled": 1,
  "location": "Building 1",
  "traps_enabled": 1,
  "trigger_test_trap": 1
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1179738
Cluster identification not available for modification since a cluster has not been created.
1179739
Cluster identification modification is not available in maintenance mode or other boot modes.
string
snmp
Cluster-wide SNMP configuration.
auth_traps_enabled
boolean
contact
string
enabled
boolean
location
string
traps_enabled
boolean
trigger_test_trap
boolean
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
