Update the cluster-wide SNMP configuration
Updates the cluster-wide SNMP configuration to manage settings such as enabling SNMP, configuring SNMP traps, and setting server contact information. Use this endpoint to ensure SNMP settings align with your network management requirements.
HTTP method and endpoint
PATCH /support/snmp
Introduced in
ONTAP 9.7
Usage notes
Updates the cluster wide SNMP configuration, such as:
enabling or disabling SNMP
enabling or disabling SNMP traps
enabling or disabling authentication traps
setting the contact and location information for the SNMP server
triggering an SNMP test trap
Related ONTAP commands
options snmp.enable -
system snmp authtrap -
system snmp init
Learn more
Request Body
| Name | Type | Description |
auth_traps_enabled |
boolean |
Specifies whether to enable or disable SNMP authentication traps. |
contact |
string |
Specifies the contact person for the SNMP server |
enabled |
boolean |
Specifies whether to enable or disable SNMP. |
location |
string |
Specifies the location of the SNMP server |
traps_enabled |
boolean |
Specifies whether to enable or disable SNMP traps. |
trigger_test_trap |
boolean |
Trigger a test SNMP trap. |
Example request
"auth_traps_enabled": 1,
"contact": "support@company.com",
"enabled": 1,
"location": "Building 1",
"traps_enabled": 1,
"trigger_test_trap": 1
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1179738 |
Cluster identification not available for modification since a cluster has not been created. |
1179739 |
Cluster identification modification is not available in maintenance mode or other boot modes. |
href |
string |
self_link
snmp
Cluster-wide SNMP configuration.
boolean |
contact |
string |
enabled |
boolean |
location |
string |
traps_enabled |
boolean |
trigger_test_trap |
boolean |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
