Create a share-level ACL on a CIFS share
Creates a share-level ACL on a CIFS share to define access permissions for users or groups on the specified share. Use this operation to manage access control settings, ensuring appropriate permissions are set for resources.
HTTP method and endpoint
POST /protocols/cifs/shares/{svm.uuid}/{share}/acls
Introduced in
ONTAP 9.6
Required properties
svm.uuidorsvm.name- Existing SVM in which to create the share acl. -
share- Existing CIFS share in which to create the share acl. -
user_or_group- Existing user or group name for which the acl is added on the CIFS share. -
permission- Access rights that a user or group has on the defined CIFS share.
Default property values
type- windows
Related ONTAP commands
vserver cifs share access-control create
share |
string |
path |
True |
CIFS Share Name |
return_records |
boolean |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
permission |
string |
Specifies the access rights that a user or group has on the defined CIFS Share. The following values are allowed:
share |
string |
CIFS share name |
svm |
type |
string |
Specifies the type of the user or group to add to the access control list of a CIFS share. The following values are allowed:
user_or_group |
string |
Specifies the user or group name to add to the access control list of a CIFS share. |
Example request
"permission": "string",
"share": "string",
"svm": {
"name": "svm1",
"type": "string",
"user_or_group": "ENGDOMAIN\\ad_user"
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
655470 |
Failed to create share ACL because the share does not exist |
655446 |
Failed to create share ACL because the specified Windows user/group does not exist |
4849678 |
Failed to create share ACL because the specified UNIX user/group does not exist |
href |
string |
_links
svm
name |
string |
The name of the SVM. |
uuid |
string |
The permissions that users and groups have on a CIFS share.
permission |
string |
share |
string |
CIFS share name |
svm |
type |
string |
user_or_group |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
