REST API reference
Create a share-level ACL on a CIFS share
Creates a share-level ACL on a CIFS share to define specific access permissions for users or groups. Use this endpoint when you need to manage access controls for CIFS shares within an existing SVM.
HTTP method and endpoint
POST /protocols/cifs/shares/{svm.uuid}/{share}/acls
Introduced in
ONTAP 9.6
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create the share acl.
  • share - Existing CIFS share in which to create the share acl.
  • user_or_group - Existing user or group name for which the acl is added on the CIFS share.
  • permission - Access rights that a user or group has on the defined CIFS share.
Default property values
  • type - windows
  • vserver cifs share access-control create
share
string
path
True
CIFS Share Name
return_records
boolean
query
False
  • Default value:
svm.uuid
string
path
True
Request Body
Name Type Description
_links
_links
permission
string
Specifies the access rights that a user or group has on the defined CIFS Share. The following values are allowed:
  • no_access - User does not have CIFS share access
  • read - User has only read access
  • change - User has change access
  • full_control - User has full_control access
share
string
CIFS share name
sid
string
Specifies the user or group secure identifier (SID).
svm
svm
type
string
Specifies the type of the user or group to add to the access control list of a CIFS share. The following values are allowed:
  • windows - Windows user or group
  • unix_user - UNIX user
  • unix_group - UNIX group
user_or_group
string
Specifies the user or group name to add to the access control list of a CIFS share.
Example request
  "permission": "string",
  "share": "string",
  "sid": "S-1-5-21-256008430-3394229847-3930036330-1001",
  "svm": {
    "name": "svm1",
  "type": "string",
  "user_or_group": "ENGDOMAIN\\ad_user"
Status: 201, Created
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
655470
Failed to create share ACL because the share does not exist
655446
Failed to create share ACL because the specified Windows user/group does not exist
4849678
Failed to create share ACL because the specified UNIX user/group does not exist
string
svm
_links
_links
name
string
The name of the SVM.
uuid
string
cifs_share_acl
The permissions that users and groups have on a CIFS share.
_links
_links
permission
string
share
string
CIFS share name
sid
string
svm
svm
type
string
user_or_group
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
