Create a share-level ACL on a CIFS share
POST /protocols/cifs/shares/{svm.uuid}/{share}/acls
Introduced In: 9.6
Creates a share-level ACL on a CIFS share.
Required properties
svm.uuidorsvm.name- Existing SVM in which to create the share acl. -
share- Existing CIFS share in which to create the share acl. -
user_or_group- Existing user or group name for which the acl is added on the CIFS share. -
permission- Access rights that a user or group has on the defined CIFS share.
Default property values
type- windows
Related ONTAP commands
vserver cifs share access-control create
share  |
string  |
path  |
True  |
CIFS Share Name  |
return_records  |
boolean  |
query  |
False  |
svm.uuid  |
string  |
path  |
True  |
UUID of the SVM to which this object belongs.  |
Request Body
| Name | Type | Description |
permission  |
string  |
Specifies the access rights that a user or group has on the defined CIFS Share. The following values are allowed:
share  |
string  |
CIFS share name  |
sid  |
string  |
Specifies the user or group secure identifier (SID).  |
svm  |
SVM, applies only to SVM-scoped objects.  |
type  |
string  |
Specifies the type of the user or group to add to the access control list of a CIFS share. The following values are allowed:
user_or_group  |
string  |
Specifies the user or group name to add to the access control list of a CIFS share.  |
Example request
  "permission": "string",
  "share": "string",
  "sid": "S-1-5-21-256008430-3394229847-3930036330-1001",
  "svm": {
    "name": "svm1",
  "type": "string",
  "user_or_group": "ENGDOMAIN\\ad_user"
Status: 201, Created
Headers
| Name | Description | Type |
Location  |
Useful for tracking the resource location  |
string  |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
655446  |
Failed to resolve the security identifier (SID) for the account named {user_or_group}. Reason: {Reason}.  |
4849678  |
Failed to resolve {user_or_group} name to a UNIX ID. Reason: {Reason}.  |
href  |
string  |
_links
svm
name  |
string  |
The name of the SVM. This field cannot be specified in a PATCH method.  |
uuid  |
string  |
The unique identifier of the SVM. This field cannot be specified in a PATCH method.  |
The permissions that users and groups have on a CIFS share.
permission  |
string  |
share  |
string  |
CIFS share name  |
sid  |
string  |
svm  |
type  |
string  |
user_or_group  |
string  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
