Create a share-level ACL on a CIFS share
Creates an ACL at the share level for a CIFS share. This is useful for managing access permissions for users or groups on the specified share.
HTTP method and endpoint
POST /protocols/cifs/shares/{svm.uuid}/{share}/acls
Introduced in
ONTAP 9.6
Usage notes
Creates a share-level ACL on a CIFS share.
Required properties
svm.uuidorsvm.name- Existing SVM in which to create the share acl. -
share- Existing CIFS share in which to create the share acl. -
user_or_group- Existing user or group name for which the acl is added on the CIFS share. -
permission- Access rights that a user or group has on the defined CIFS share.
Default property values
type- windows
Related ONTAP commands
vserver cifs share access-control create
share |
string |
path |
True |
CIFS Share Name |
return_records |
boolean |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
permission |
string |
Specifies the access rights that a user or group has on the defined CIFS Share. The following values are allowed:
share |
string |
CIFS share name |
sid |
string |
Specifies the user or group secure identifier (SID). |
svm |
type |
string |
Specifies the type of the user or group to add to the access control list of a CIFS share. The following values are allowed:
unix_id |
integer |
Specifies the UNIX user or group identifier (UID/GID). |
user_or_group |
string |
Specifies the user or group name to add to the access control list of a CIFS share. |
Example request
"permission": "string",
"share": "string",
"sid": "S-1-5-21-256008430-3394229847-3930036330-1001",
"svm": {
"name": "svm1",
"type": "string",
"unix_id": 100,
"user_or_group": "ENGDOMAIN\\ad_user"
Status: 201, Created
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
655446 |
Failed to resolve the security identifier (SID) for the account named {user_or_group}. Reason: {Reason}. |
4849678 |
Failed to resolve {user_or_group} name to a UNIX ID. Reason: {Reason}. |
href |
string |
_links
svm
name |
string |
uuid |
string |
The permissions that users and groups have on a CIFS share.
permission |
string |
share |
string |
CIFS share name |
sid |
string |
svm |
type |
string |
unix_id |
integer |
user_or_group |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
